Tom's Hardware > Forum > CPU & Components > Other Components > Power supply problems
Forum CPU & Components : Other Components - Power supply problems
Heyas (cross-posted to Coolers and Heatsinks)
I recently added a couple of fans to my case, and (stupidly) didn't think much about power requirements. But when I went to boot up yesterday, a message came up during POST that my Hardware Monitor had detected an error, F1 to check or ESC to continue. I hit F1. In my Power section, under Hardware Monitor, my +5v is reading between 5.25 and 5.4 (between 5.3 and 5.4 it turns red) and my +12v is reading up to 13.5 (also red). So I figured that I must have maxed out the power supply. I disconnected a couple of fans (2 x 120mm fans) and things calmed down to normal, but the problem returned. Even with everything turned off now the +5 and +12 sometimes still redline in the BIOS. I have tried connecting it directly to the wall socket (it is connected through a UPS usually) but that didn';t do anything. My question is two-fold:
1) Did I pooch my power supply? If I leave things running so high, could I pooch any of my devices, ie. cd-rom, mobo, cpu, etc?
2) Would a bigger power supply get rid of the problem? I am going to go out after work today to get an Enermax 535 watt. Hey, why not go big? :-)
For specs, here is my machine:
Aopen HQ-08 case
Asus P4T-E mobo
Intel P4-1.7 ghz
512 MB RDRAM
Maxtor 60gig HD
Maxtor 40gig HD
Acer DVD-ROM
Acer CD-RW
1.4MB Floppy drive
Asus GF3 v8200
Creative Labs SB Live! Value
ATI TV Tuner card (to be replaced with something else)
10/100 NIC
2 extra USB ports (included with mobo, taking up a slot in the back)
Stock heatsink/fan on the P4
Two 80mm 12V Fans
One 60mm 12v Fan
Two 120mm 12V Fans
And I _think_ the power supply is 300W
So what's the consensus? Did I pooch something in my PS? Can I run my machine for limited periods of time (I run a small business and need to print paycheques ASAP, should only take 5 minutes of up-time)? Will the new PS help?
Thanks for any and all replies. I should have been paying more attention to how much power I was gonna be pulling. Lesson learned.
TheSmokey
Sponsored Links
You should replace your power supply. The voltage regulator must be failing if the reading is too high. If you were simply overloading it, the reading would be too low. You should probably go with at least a 350 watt.
Antec and Enermax both make very quiet 350+ power supplies. They cost more but you get what you pay for.
<i>Speed doesn't kill,</i> <b>lag does.</b> :cool: James
Reply to ravenprime
Heyas
Thanks for the explanation. I replaced my psu with an Enermax EG651P-VE FMA 550 watt. Solved all my problems. Except the noise, but I'm putting a rheabur together for that ;-) Thanks for the help
TheSmokey
Reply to The_Smokey
don't blame the noise on that power supply, it got to be something else. mine is super silent since the fans in it barely spin at idle
<font color=red>Got a silent setup, now I can hear myself thinking.... great silence</font color=red>
Reply to AndrewT
I agree. My Enermax is very quiet too. I think the noise most likely come from GPU or CPU fan.
Reply to upec
Double check your fans. If one of them's locked up or having problems they tend to draw a LOT more power then when they're working properly.
AntecRep
Reply to AntecRep
Thats odd, I too have a 550W enermax PSU and its as quiet as a mouse. Its the slightly older version where the fan speeds are controlled by temperature.
As the Unit never runs anywhere near full load, it runs quite cool, the fans run slow and its silent compared to other noise making devices in my case like 7200rpm hard drives.
Even when it does run at full speed its barely above a whisper. (And its not even a whisper PSU LOL)
<b>And if you gaze for long into Toms Hardware Forums, The Forum gazes also into you! :eek: </b>
Reply to lhgpoobaa
Oops
By the noise I meant the noise generated by all the casa fans, not the power supply. I tried the power supply by itself before plugging the fans in and agree, it is almost inaudible.
Sorry for the confusion :-)
TheSmokey
Reply to The_Smokey
There are 823 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
