Tom's Hardware > Forum > Audio > Pro Audio > Best Low Latency Audio Card?...
Forum Audio : Pro Audio - Best Low Latency Audio Card?...
Archived from groups: rec.audio.pro (More info?)
Doing a lot of midi stuff (with Live, Cubase, Sonar, Project5, Acid etc.)
and want to upgrade my card (have a SB Live) to a low or no latency card.
I've heard M-Audio's Audiophile 2496 PCI card is one of the best. I am using
a USB M-Audio Keystation 49e.
Any in the $100 or so price range that are worth considering? Or is the 2496
the best?
Thanks!
Frank
Sponsored Links
emu 0404
http://www.emu.com
regards
emil
"Frank McMahon" <frankmcma@yahoo.com> wrote in message
news:S7cbd.8918$l07.4616@twister.nyroc.rr.com...
using
2496
> the best?
> Thanks!
> Frank
Reply to Emil
In article <ckjjsv$ta5$1@ls219.htnet.hr> emil@maknisonarscope.hr writes:
> emu 0404
What latency have you measured, and how did you measure it? Or are you
just passing on the "very low latency" ad copy?
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
- 0 +
in a price range around 100$
is just few cards with resonable "very low latency"
and one of this is EMU 0404 - did not measure
just play with VST istruments
but if You have some simple way to mesure latency i can test few cards
and poot result here
Best Regards
emil
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1097690996k@trad...
> > emu 0404
Reply to Emil
In article <ckkacf$rt1$1@ls219.htnet.hr> emil@maknisonarscope.hr writes:
There are a number of things that are called "latency." The thing that
concerns me most is the time between when audio (like a microphone)
hits the input and when it comes out the monitor output. You can
measure this by putting something with a short rise time (a cross
stick sound is good) into one channel, and connect the output of that
channel to the input of another channel. Record a few seconds on both
channels. Stop the recording, zoom in on the waveform of the two
channels, and measure the time difference between them. That's the
input/output latency.
Latency when playing samples is trickier because it depends on the
program that's supporting the VST instrument. If you have a MIDI
keyboard with sounds you could choose a similar sound on the keyboard
and from the VST library, connect the analog output of the sample
playback channel to one input, connect the synth output to another
input, play your sound, record it to two tracks, and look at the time
difference between the tracks. That's not totally accurate but it will
get you a ballpark measurement.
Reply to Anonymous
Mike, emil or anyone else...not sure what type of latencys there are but
here is what I need: I need a setup that when I hit a note I hear it through
the monitor at the same time, and I also need that sound recorded at the
exact same time in my program.
There are some cards that offer zero latency monitoring, which I guess is
not terribly hard to offer with the correct cabling, but I am most
interested in playing back a midi track with say a drum beat and then laying
down a second drum track where I am playing in real time to the beat of the
tracked played back, and I am hitting the notes on my keyboard exactly on
cue.
Right now I have a sound blaster live and an M-audio Keystation 49e that is
hooked up via a USB (1.0 I believe)
Using programs such as live, sonar, etc I want to make sure that if I am
playing a metrodone in live and I hit a key at the exact time as it clicks,
that when I play it back it is right at that exact time.
Not sure what would help..but the two audio cards discussed seemed to be
highly rated. I am also now wondering if I should get a card with an actual
midi port and use my keyboard midi port, as opposed to the plug and play USB
cable.
Hopefully this explains it better...and any suggestions you would have, for
a card, setup or port, would be great..thanks!
Frank
news:znr1097708571k@trad...
Reply to Anonymous
In article <_Svbd.300332$bp1.175681@twister.nyroc.rr.com> frankmcma@yahoo.com writes:
You'll never get it exact, but about 5 milliseconds delay is tolerable
for just about any musician.
> cue.
The only true zero latency monitoring is with an analog path from the
input sound source (there is none with a virtual synth, but this works
with a microphone) to the monitor output.
I have heard reports of some really horrible (like 500 ms) latencies,
but most are far better than that. I'd suggest that you go to a dealer
or a friend with a setup that's capable of doing the recording
functions you want to do, and just sit down and give it a try.
I'm really Mike Rivers - (mrivers@d-and-d.com)
Reply to Anonymous
On Thu, 14 Oct 2004 14:16:26 GMT, "Frank McMahon"
>cue.
>cable.
Mike is not looking at the problem from a musician's viewpoint,
certainly not a musician using the software synths and samplers
included with programs such as Sonar.
If this is what you're doing, I suggest you read the discussion of
latency on my Cubase FAQ page. It is equally applicable to other
similar programs.
Your problem isn't the midi interface.
Your SB live possibly is.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
There are 1250 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
