Wifi speed test
Last response: in Wireless Networking
September 28, 2012 5:37:02 PM
Hello,
What is minimum or maximum rage of speed is good for use
More about : wifi speed test
October 2, 2012 6:53:15 PM
Most wifi speeds are equal to or higher than your incoming connection from whatever ISP you use. Me, for example... I have 30mbit Cable, so as long as my wifi connection stays at 30mbit, technically I am able to use my whole pipe coming in. If my wifi goes to 300mbit, that's 270mbit NOT being used for internet, but the faster speed comes in handy if you are doing file transfers across you LAN.
m
l
