Tom's Hardware > Forum > Audio > Pro Audio > Sound isolation questions
Forum Audio : Pro Audio - Sound isolation questions
Archived from groups: rec.audio.pro (More info?)
Hi Everyone,
Thought I would post a follow up to my last post. I have done more research,
and here is what I found. Many people seem to recommend the following
approach:
1. Apply mass-loaded-vinyl (1lb/sq ft) to walls - either directly (if it has
the foam backing) or on top of firring.
2. If 1 above is sufficient, apply sheetrock using standard construction. If
not, build resilient channel on top of MLV and apply sheet rock.
I have a drop ceiling, so I could apply the MLV easily enough. The floor
also has ceramic tiles (as does the adjacent control room...) which of
course are problematic. I would apply MLV there too.
In each case, none of the added construction will touch existing walls,
floor or ceiling. Acoustical caulk would be used to fill in gaps and
perimeter.
I have also read about QuietRock. But I have found no pricing info which is
scary. They claim MLV actually only adds about 3-4dB to the STC. In any
case, the MLV generally goes for around $200 for a 4.5' x 30' roll (closer
to $300 for the stuff with foam backing).
What do you think?
Out of curiosity, what SPL would you expect to be coming out of a guitar cab
for recording purposes (measured a foot away)? I am trying to get a feel for
how loud people crank amps in a studio.
thanks,
brian
Sponsored Links
> What do you think?
Interesting. I did a search and found a site that claims their vinyl
barrier is 2 1/2 times cheaper than homosote. That sounds like a damned
good deal.
One thing I'll tell you, my general experience with sound proofing is that
it's better to go overboard than to be conservative. I've done this twice
now and both times I've been surprised how much sound still manages to get
out from a live band after applying what I initially thought was over kill.
Again, the kick drum and low bass notes are the biggest problem. My success
for guitars has been acceptable.
I solved the drum problem by buying a set of V drums.
--Nick
Reply to nick
"Brian Huether
> cab for recording purposes (measured a foot away)? I am trying to get a
> feel for how loud people crank amps in a studio.
** Expect up to 130 dB SPL with a mic at 12 inches with say a 100 watt
Boogie.
........... Phil
Reply to Anonymous
"Brian Huether" <bhuetherNO@guitarSP-dreams.AMcom> wrote in message
news:1098022969.eN2ZOwNuodbYsFTnaYzspg@teranews...
cab
for
Anything from loud conversational level (say 82dB, with a small amp) to
140dBA. I usually go the small amp route myself, but in the account of the
recording of "Brown Sugar" at Muscle Shoals they note that Keith's amp
(Ampeg stack?) was cranked wide open. It was, of course, in an iso room.
Peace,
Paul
Reply to Anonymous
"Paul Stamler" wrote:
> cab
> for
According to Jimmy Johnson in that Tape Op interview, it was a wide open
Fender Twin. It was so loud that he had to use a 77DX and a 20db pad to get
the level down enough so the input of the mic amp wouldn't clip .
-jw
Reply to Anonymous
There are 1276 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
