Tom's Hardware > Forum > Audio > Pro Audio > Monitoring: Help, what I hear is not what I get!
Forum Audio : Pro Audio - Monitoring: Help, what I hear is not what I get!
Archived from groups: rec.audio.pro (More info?)
I'm experiencing a problem with almost any DAW program I tried until now.
What I've noticed is that the playback of audio actually recorded on HD is
sensibly brighter than what I hear during direct input monitoring. I made
some tests using Logic Platinum and Sonar 4 PE (WinXP) with various mixer
configurations: ie audio chain passing thru plugin FX or going directly to
master output, with both ASIO and WDM audio drivers, all at 24 bits 48kHz
and 96kHz. Monitoring and playback signals follow the exact same audio path
no external gear is introduced, I'm using an Echo Layla24 connected directly
via balanced audio cable to a pair of Genelec 1030A Monitors. In all of
these tests I had the same results the recorded audio has a high frequency
boost. Anybody as a clue about what's going on?
Thanks in advance.
Paolo
Sponsored Links
"Paolo Garuti" <paolo.garuti@tin.it> wrote in message
news:PoAdd.173782$35.8354786@news4.tin.it...
path
directly
> Thanks in advance.
> Paolo
Sounds like pre-emphasis is engaged on recording and not being de-emphasized
on playback. Check to see if the pre-emphasis flag is getting mangled
somewhere.
bobs
Bob Smith
BS Studios
we organize chaos
http://www.bsstudios.com
Reply to Anonymous
....Anybody as a clue about what's going on?
Brightness is the classic jitter symptom.
There's no substitute for a jitter proof D to A converter if you are using a
workstation. I recommend Benchmark Media or Lavry.
Bob Olhsson Audio Mastery, Nashville TN
Mastering, Audio for Picture, Mix Evaluation and Quality Control
Over 40 years making people sound better than they ever imagined!
615.385.8051 http://www.hyperback.com
Reply to Anonymous
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
