V600 doesn't ring when paired w/ HS801 Bluetooth
Archived from groups: alt.cellular.motorola (More info?)
I just bought a Motorla Bluetooth headset (HS801). When paired w/ my V600,
the phone does not ring! It only rings through the headset itself meaning
that you have to have the headset on your ear in order to hear the phone
ring (unless of course it's on Vibrate+Ring in which case the phone itself
will only vibrate). I can't have the thing on my ear all the time! What
should I do?
Thanks in advance!
Amir
1 answer Last reply
More about v600 doesn ring paired hs801 bluetooth
  1. Archived from groups: alt.cellular.motorola (More info?)
    AFAIK, that's the way the V600 works then paired with a BT headset.
    Try going to motorola.howardforums.com and do a search.
    >should I do?
    >Thanks in advance!
    >Amir
    ___________
    **Remove NOSPAM from email address to reply**
Motorola Gaming Headsets Bluetooth Phones
