Pressed something accidentally and it just posted.
My question is:
1. If i buy a router like a Belkin N600, its advertised as "300mbs", does that mean that it can handle up to that speed? So my 18Mbit/s internet will not have a problem with this?
http://www.amazon.co.uk/exec/obidos/ASIN/B005626U9W/ref=nosim/6553229-rg4277-21
2. My internet is running on my phoneline and NOT fibre optic. Will this Belkin N600 be suitable or is there different versions for phoneline and fibre optic? Are the connections, the (as is says on my router atm) ADSL port thesame as fibre optic ones?
3. If i do buy the N600, will i just remove my current router now and replace it with the N600? Will i need to configure the internet connections setting for my ISP through the router settings?
4. What if i buy two routers. One will be downstairs and one upstairs, as each room in my house has a telephone line socket, obviously both will have the 'filter'. Will my internet be halfed, so 9Mbit/s(max) on one router and 9Mbit/s(max) on the other? Any problems with doing this?
5. Any other router out there <£100 that are good and you guys would recommend? Ideally needs to be 802.11n
