re strange masterlink peavey vmp2 problem
Last response: in Home Audio
October 22, 2004 9:56:58 PM
Archived from groups: rec.audio.pro (More info?)
i posted a while back about a problem with recording on one channel of a
masterlink via peavey vmp2
i fixed the problem, but i'm still curious about it. the problem was that
even in recording just one channel i would get signal on both channels, and
both channels sounded crackly.
the masterlink has two sets of inputs, rca and balanced xlr.
the recording setup being used is attached to a consumer stereo system with
cassete, phonograph, and cd.
both sets of inputs on the masterlink were connected. and i have the same
setup at home with a masterlink and stereo system.
turns out that somehow the masterlink was using both sets of inputs at the
same time. i would think there would be some sort of automatic defeat so
that it would only use rca or xlr at any given time. and i have never had
this problem at home, but it seems that with this setup there was some
signal coming off of the amp and into the rca inputs. i disconnected the rca
input cables to the masterlink and the crackling went away
any ideas on why this happened?
Anonymous
October 22, 2004 9:56:59 PM
Don't do this.
Because the inputs are paralleled.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
