Tom's Hardware > Forum > Audio > Pro Audio > Audio File Conversion Issues
Forum Audio : Pro Audio - Audio File Conversion Issues
Archived from groups: rec.audio.pro (More info?)
I am aware of the issues one can encounter editing the bit depth and
sampling rate of audio files on a mediocre DAW. What I am trying to
deduce are the anomalies, issues and negative attributes that are
introduced by converting file types.
Example:
In Sound Forge, saving a WAV file off as an AIFF or SD or SDII files.
Your input is appreciated.
Sponsored Links
R Speck <hh@hh.com> wrote in news:5g3ln0led5s3ti3pvr5nas7a3de424mafh@
4ax.com:
> Example:
As long as the destination filetype supports the original word length &
sample rate, None.
Reply to Anonymous
"R Speck" <hh@hh.com> wrote in message
news:5g3ln0led5s3ti3pvr5nas7a3de424mafh@4ax.com...
There is one file type to avoid which is Sound Designer II. It requires a
Mac-only disk format (the resource fork) that has been obsolete for ten
years and probably won't even be compatible with new Macs in a very few
years.
Bob Olhsson Audio Mastery, Nashville TN
Mastering, Audio for Picture, Mix Evaluation and Quality Control
Over 40 years making people sound better than they ever imagined!
615.385.8051 http://www.hyperback.com
Reply to Anonymous
>Example:
There should be none. The bits are the the same, only the headers are
different.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
> Example:
By coincidence, last week I had the occasion to test this. I made a copy of
a .wav file, inverted its polarity, and saved it as an AIFF file. I then
imported it into a program which has intermittent problems reading 32-bit
..wav files (that's an issue for another thread), which automatically
converted it back into a .wav file. Finally, I re-imported the newly created
..wav file (on which I had done no operations) into a multitrack program
along with my original file and played them back simultaneously.
Result: nada. Nothing. Zilch. The two opposite-polarity files nulled
perfectly.
My conclusion: at least in CoolEdit/Audition and DC-SIX, saving a file in
..wav or AIFF makes no substantive difference whatsoever. Just different ways
of writing identical data.
Peace,
Paul
Reply to Anonymous
My thanks to all of you that responded. I can feel confident in my WAV
- AIFF conversions now
Reply to Anonymous
There are 1407 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
