I have two WD 200JB drives and two Maxtor 160 gig drives, the Western Digital drives are connected to an onboard Promise 20276 port and set as Single, the Maxtor Drives are connected to a Promise Ultra133 TX2 card and set as masters I am using 80 wire cables and have tried the drives on both the end connector and what I usually use as the secondary connector, this has same configuration has been used on both VIA chipsets with a AMD Athlon XP processor and Intel Chipsets with a Pentium 4 processor.
I have tried several different combinations and motherboards and this is just my current configuration.
Using various sound cards there seems to be some problem with the sound, most noticablly the wave channel, where the sound stutters, this is very bad with products that are based on Creative's chips, but I can still occansionally notice a problem with a Santa Cruz card as well.
So my question is:
If I move to a single card solution,
1. Will my sound problems be resolved by using a high end raid card, such as, for example, the Promise SuperTrak100?
2. If I move to a high end raid card, is there any problems just keeping my drives "as is"?
I am leaning towards a 6 channel card, as then I can move to a raid 5 solution for each set of disks, but at the moment I need to know if this is a problem that can be resolved.
Thanks in advance.
So my question is:
Thanks in advance.
