What is my lan connection speed
How do i check my LAN connection speed- is the same as the speedtest t I run from the internet ?
1 answer Last reply
More about what connection speed
  1. Use LAN Speed Test: http://download.cnet.com/LAN-Speed-Test/3000-2085_4-10908738.html This program copies a small test file and measures the connection from device to device on your network.
    The Internet run test will only show you if you are getting the same Internet connection speeds but will not give you an actual LAN speed if it exceeds your Internet connection.
LAN Connection LAN Internet Networking
