Tom's Hardware > Forum > Audio > Pro Audio > Flying Mics
Flying Mics
Forum Audio : Pro Audio - Flying Mics
Archived from groups: rec.audio.pro (More info?)
I have a pair of mics with a diameter of 22 mm that I would like to be able
to hang. The only kinds of mounts I've seen are for smaller choir-type
microphones. Anyone know if such a harness exists for a larger diamter mic?
Thanks.
Thomas
Sponsored Links
Go to www.neumann.com
click on info pool
select type accessory parts
scroll down and select Auditorium Hanger MNV 21 mt
the other option is just using a string to the front of the mic and connect
to the cable a foot or so from the connector..... adjust length for desired
angle.....
Rgds:
Eric
www.webermusic.com
"Thomas Bishop" <bishopthomas@sbcglobal.net> wrote in message
news:_o8gd.2029$fC4.1419@newssvr11.news.prodigy.com...
able
mic?
> Thanks.
> Thomas
Reply to Anonymous
"Eric K. Weber" <eric-nospam@webermusic.com> wrote in message
> click on info pool
> connect
> desired
> angle.....
That's exactly what I was looking for. Thanks a lot. Now to find out what
quality gold this thing's made of.
Reply to Anonymous
Glad to be of help, they are about $40... and are made for Gotham GAC-2 size
cable .21 inch diameter or smaller.
Another cheaper alternative is to use your existing stand mount, and a six
inch or longer stub of a stand or an adapter to 1/4 inch available at photo
stores... then a 6 inch or longer 1/4 inch bolt..... use gaffer tape to
tape the cord back to the 1/4 inch bolt....
Rgds:
Eric
news:qyhgd.5347$bP2.2762@newssvr12.news.prodigy.com...
> > click on info pool
> > connect
> > desired
> > angle.....
what
Reply to Anonymous
An option is to go for the Microphone "slug" on the market- AEA sells one
for about $10. Basically a little piece of metal with a 5/8"-27 thread and
a groove for a cable. Then you use whatever mount you already own for the
mic...
--Ben
Benjamin Maas
Fifth Circle Audio
Los Angeles, CA
http://www.fifthcircle.com
Please remove "Nospam" from address for replies
>mic? Thanks.
> Thomas
Reply to Anonymous
There are 1125 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
