recorded fine with Omnistudio USB and Cubase SX 2 for about an hour and then
the output became distorted, levels were normal, no clipping.. had to
restart to stop the buzzing.. now, it distorts every time after a few
minutes of recording..
On Sun, 31 Oct 2004 09:44:40 +0000, Pooh Bear
>Sounds like it's broken to me.
>Take it back for replacement.
>Graham
Is it hot to the touch? Sounds like a heat problem. Works ok, then
gets hot and distorts. Back it goes. If it has a wall wart plug in to
power it that might be what gets hot, not the USB part. Try it on
another computer. Good luck. s.
"td" <yaspb2002@hotmail.com> wrote in message
newsi2hd.36989$QJ3.15007@newssvr21.news.prodigy.com...
then
I have this same problem with a M-audio 410 firewire
unit is with a friend for testing on other computers
we suspect a bad driver from m-audio
but testing is not done yet
m-audio was worthless as far as customer service goes
George
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.773 / Virus Database: 520 - Release Date: 10/5/2004
you telling me... those idiots just told me the problem happened because my
computer went into sleep mode.
"George Gleason" <g.p.gleason@worldnet.att.net> wrote in message
news:mychd.49496$OD2.20018@bgtnsc05-news.ops.worldnet.att.net...
> then
> George
"Bob Cain" <arcane@arcanemethods.com> wrote in message
news:cm3nfu0nb@enews4.newsguy.com...
> What's that?
> Bob
> "Things should be described as simply as possible, but no simpler."
> A. Einstein
