Tom's Hardware > Forum > Audio > Pro Audio > previous versions of audio codecs
Forum Audio : Pro Audio - previous versions of audio codecs
Archived from groups: rec.audio.pro (More info?)
In order to do codecs comparison, I need to encode files with previous
versions of RealMedia encoder and WindowsMedia encoder. Does anyone
knows where I can find these softwares or a soft doing that? From now
I've only found the latest versions of these encoders. I would need to
encode files using codecs of RealAudio 4, 5, 6 and WM encoder 6, 7.
Thanks,
Remi
Sponsored Links
previous
to
> Thanks,
> Remi
Hi Remi. You can try:
http://www.oldversion.com
I have seen previous verions of the various media players there.
Encoders may be there as well.
Regards,
Hassan
Reply to Anonymous
previous
to
> Thanks,
> Remi
Regards,
Hassan
Reply to Anonymous
There are 551 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
