G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.flight-sim (More info?)
Got a problem if anyone can help.
I'm trying to install CFS2 on a perfectly working high end gaming computer
with absolutely 0 issues with the optical drive. FS9 is installed and
running perfectly. All hardware and software is fine.
I've had CFS2 installed and running at different times with no installation
issues. It's been out of the system for awhile now. Disc 1 and 2 are
pristine with no defects.
What's happening is that when I put disk 1 into the drive, the drive makes
slight noises above that which is normal. The autoplay works eventually, but
is extremely slow. The noise continues with a very slow installation. Disk 2
makes no noise and installs ok, but the sim won't run.
I'm sure it has something to do with the #1 disk but can't nail it down. D
drive accepts every other program disk except the #1 on CF2, which ran
perfectly before.
The obvious issue would point to the CD, but it's absolutely perfect as far
as I can see.
Has anyone had installation issues with CFS2?
The GPU is an EVGA GeForce 6800GT 259 running FS9 perfectly. The drivers are
EVGA WHQL 7.7.7.2.
Any help will be greatly appreciated.
Thanks
Dudley Henriques
International Fighter Pilots Fellowship
perfectly before.
as I can see.
EVGA WHQL 7.7.7.2.
Thanks
Dudley Henriques
