1 bar wireless connection with hp?
Hello,
I just purchased a brand new HP Envy dv6 laptop and I only get 1-2 bar of connection for my wireless, yet my 2 year old MacBook laptop gets a solid 5 bar connection!? What's up with that?
4 answers Last reply
More about wireless connection
  1. Sorry for the thread duplicate, for some reason it bugged out and made 2 and I don't know how to delete it because I just joined. :(
  2. Hello and welcome to Tom's Hardware Forums.
    I suggest you check the channel the router is broadcasting on and match it in the wireless adapter's configuration settings.
    Don't worry abut the duplicate - it happens a lot. I'll post into it to help preventing anyone else doing so.
  3. Hey Saga thank you for your reply. How can I change my wireless adapter's configuration settings to match the routers channel? I do know what channel my router is broadcasting though. Also, thank you for posting in my other thread as well.
    Edit: I am using Windows 8. :)
    The wireless adapter's properties are in Control Panel>Network and Sharing Centre>Manage Wireless Networks and Change Adapter Properties. Set that to the same number you set in the router and they should talk to each other properly.
Wireless Laptops Connection Hewlett Packard Networking
