I can have 5 fans in this case, 2 on the top, 2 on the bottom and 1 at the side..
One guy I talked to also suggested 1 sidefan, 1-2 on the bottom and then carve a hole in the roof for a 120mm fan..
Aluminum will disapate heat better than steel. I was wondering though, what the hell are you planning on building that you need that many fans in the case? Man, that thing will sound like a tornado sitting there with 5 fans running! Talk about over kill...........
UsHeR_564
"You can run, but your punk ass will only die tired!"
