Tom's Hardware > Forum > Audio > Pro Audio > AKG C-414 B-ULS TL II - Intermitant noise problem
Forum Audio : Pro Audio - AKG C-414 B-ULS TL II - Intermitant noise problem
Archived from groups: rec.audio.pro (More info?)
Hi everyone,
I've got an AKG C-414 B-ULS TL II with a noise problem.
I'm getting sound, through but with a little more hiss and the
biggest problem is every few seconds there's like a "pumping"
noise that'll happen 1-4 times, then stops and does it again after
a bit. It doesn't happen at regular intervals....
Anyone have an idea what it could be?
Has anybody has this happen before?
Perhaps the 2 large Caps are going?
Any help is appreciated.
Thanks.
Mario
Sponsored Links
On Wed, 3 Nov 2004 21:38:06 -0500, "Vortex" <nospam@overhere.com>
wrote:
>Hi everyone,
It could be moisture. Leave the mic on overnight and place it in
front of a loudspeaker, table radio, or anything that will give the
capsule(s) something to do. Any excess wet should be cooked an shaken
out by morning.
http://liondogmusic.com
Reply to Anonymous
<< It could be moisture. Leave the mic on overnight and place it in
out by morning.
Don't know about the shaking, but I used to dry a U87 that had too much breath
moisture build up by placing it a couple feet above a 50 watt lamp for a few
hours.
Scott Fraser
Reply to Anonymous
>out by morning.
>hours.
>Scott Fraser
Done that, too on real stubborn units or if I'm in a hurry.
Reply to Anonymous
A friend of mine likes to tell the tale of when he was a tape op and there
was some really obnoxious client demanding all the U87's they had, one of
which had a slightly damp capsule. To get things moving quick and avoid
further abuse, he attempted to dry it with a hair dryer placed, so he
thought, at a safe enough distance that it couldn't possibly damage the gold
foil .............
"Vortex" <nospam@overhere.com> wrote in message
news:fvgid.20402$dj2.1060420@news20.bellglobal.com...
> Hi everyone,
> Thanks.
> Mario
Reply to Anonymous
In article <20041103233047.21876.00000038@mb-m14.aol.com>,
>out by morning.
>hours.
That is often a sign that the diaphragm has become dirty, and that the dirt
is absorbing moisture and becoming conductive. Certainly capsule cleaning
would not hurt once you have verified that drying it out fixes the problem.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
- 0 +
Some 414 mmodelss have switches that become noisy, in particular-move
the hii-pas from side to side a number of times.
micha
>> Hi everyone,
>> Thanks.
>> Mario
Reply to ms
In article <i5gro019anvghmk90q16q8cucucln4ao8g@4ax.com>, ms <micha@att.net>
> micha
> >> Hi everyone,
> >> Thanks.
> >> Mario
I had a similar problem that turned out to be due to transformer failure: yes,
there is a transformer in the TL II, but not in the direct signal path. (It
feeds phantom power to the capsule.)
-Jay
x------- Jay Kadis ------- x---- Jay's Attic Studio ------x
x Lecturer, Audio Engineer x Dexter Records x
x CCRMA, Stanford University x http://www.offbeats.com/ x
x---------- http://ccrma.stanford.edu/~jay/ ------------x
Reply to Anonymous
There are 1312 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
