The solution to our nuke waste problem - page 2
74 answers Last reply
  1. Archived from groups: rec.audio.pro (More info?)
    Roger W. Norman wrote:
    > And how did they measure the half-life? Wait around 4.5 billion years
    > before coming up with the result?
    Well, no, radioactive elements decay by emitting (surprise) bursts of
    radiation. So you use something to measure the decay events, like a
    geiger counter or something with phosphorous and an optical detector.
    You measure decay events for a period of time, and then you can figure
    out the rate at which decay events are happening. Then it's just
    some simple math to determine the half-life.
    And no, you'll never be sure that you get exactly the right answer.
    But then, one of the interesting things about radioactive decay is
    that there IS no right answer. As far as science can tell (if I
    understand this correctly), any individual atom is just sitting
    there and during one second of time, it has some small probability
    of "deciding" to decay. If, during that first interval, it doesn't
    decay, then during the next one-second interval, it has exactly the
    same probability as it did in the previous interval. So you could
    in theory have a chunk of something radioactive sitting there, and
    you could have no decay occur during the first second, and then
    you'd be *exactly* where you started a second ago. This is very
    unlike doing math with a car traveling down the road at a constant
    70mph. With the car, you can say that one second later, it will
    about 103 ft further down the road. Radioactive decay would be
    more like a car where you never actually take your foot off the
    brake, and the wheels never roll, but about every second or so,
    it teleports itself to a position 103 ft further down the road[1].
    So anyway, after all that the point is that the half-life can only
    be measured approximately, so they don't know that it's exactly
    4.5 billion years, although they can be quite confident that it's
    awefully likely to be very close to 4.5 billion years.
    But, the half-life isn't all that important. All it tells you
    is how quickly something is spitting out radiation. It is
    somewhat informative because things with long half-lives are
    not going to spit out radiation very fast; otherwise, they'd
    spit it all out long before 4.5 billion years' time. The
    important thing is really what kind of radiation is coming
    out and how much. And *that* can be measured pretty directly.
    Well, also, the more important thing is the damaging *chemical*
    effects of heavy metals like uranium. Uranium is dangerous
    for the same sorts of reasons that you can get lead poisoning.
    - Logan
    [1] Actually, it would be more like a greyhound bus full of
    little ants, and each ant has a little button he can press
    that will teleport the bus 103 ft down the road, but each
    ant can only press his button one time, and you can't really
    predict when he will do it, and the ants don't act in a
    coordinated fashion at all.
  2. Archived from groups: rec.audio.pro (More info?)
    Actually you're getting into probability, which suggests that one can't
    predict WHICH atom will decide to decay. The fact is that at least ONE atom
    will decay at a predicted time. In an entirely unstable isotope, the
    probability becomes a universe where ALL the atoms can decide to decay at
    the exact same time, which means boom.
    Roger W. Norman
    SirMusic Studio
    "Logan Shaw" <lshaw-usenet@austin.rr.com> wrote in message
    news:G8Pjd.38766$tL5.17545@fe2.texas.rr.com...
    > - Logan
  3. Archived from groups: rec.audio.pro (More info?)
    "Roger W. Norman" <rnorman@starpower.net> wrote in message
    news:Sp-dndisNpZwKhLcRVn-2w@rcn.net...
    > Didn't you read George's original post relating to a reported tonnage of
    630
    > thousand tons? Even if it were somewhere on the order of 1% of that,
    we're
    > still talking about a lot of tons of material.
    Nope, missed that. Seems a bit high, since only 320 tons were expended in
    the first Gulf War.
    http://www.deploymentlink.osd.mil/du_library/gulfwar.shtml
    An increase of three orders of magnitude seems a bit high.
    Let's look at the numbers. The US fired about 50 tons of DU tank rounds in
    the first Gulf War. Assuming a 90% hit rate (the penetrator only forms dust
    when it hits a hard target like steel armor), that leaves 45 tons of hits.
    With a 99% pyrophoric consumption (estimated; I couldn't find the real
    figure online), that leaves less than 1000 lbs of dust. And most of that
    should remain inside the destroyed vehicles.
    And the radioactive danger from something with a 4.5 billion year half-life
    is pretty small compared to everything else in the world that can kill you.
    Glenn D.
  4. Archived from groups: rec.audio.pro (More info?)
    And how many 100s of days did the first Gulf war take compared to the 20
    months of war we have now?
    Roger W. Norman
    SirMusic Studio
    "Glenn Dowdy" <glenn.no.dowdy@hpspam.com> wrote in message
    news:YePjd.2525$yU6.2291@news.cpqcorp.net...
    > 630
    > we're
    > the first Gulf War.
    dust
    half-life
    you.
    > Glenn D.
  5. Archived from groups: rec.audio.pro (More info?)
    It's also NOT the possible radioactive debris that's a problem, it's the
    heavy metal component in the soil and the fine dust in the air.
    And the question becomes whether it's reasonable to have ANY munitions that
    could leave the place you are fighting for as some level of unusable
    territory. If it can't be used, then it's a totally different set of
    circumstances that prevail. For instance, if Iraq is decimated beyond the
    ability to recover from the ecological import, then we have the ability to
    enforce our will and maintain our hold on the oil, which is most certainly
    becoming a major financial quagmire on it's own. On the other hand, if we
    take the people (both our troops and the Iraqi people) into consideration,
    then perhaps it's better to find some other method to accomplish the goals.
    Yes, the war is on, big time, especially right now, but is it the right
    thing at the right time with the right combination of elements that comprise
    the war, then I can only say I don't believe so. What I do believe is that
    what we've dumped on Iraq is enough that we will be able to follow the
    results of it pretty well in the years to come. I'd prefer that when we
    have those studies, we (the American people) don't come up the bad guys by
    introducing yet another problem on a people that have had 30 years of
    nothing but problems.
    It's already too late to assume that the historical records won't suggest
    the above alone, much less with the additional problems of the types of
    armament.
    Roger W. Norman
    SirMusic Studio
    > 630
    > we're
    > the first Gulf War.
    dust
    half-life
    you.
    > Glenn D.
  6. Archived from groups: rec.audio.pro (More info?)
    news:DImdnX1vge7kXhLcRVn-rg@rcn.net...
    > I said "get's hit" which precludes missing, my man! <g>
    > And M16 fires a .223 caliber bullet, but one would be hard put to have any
    > weapons person dismiss a .22 as a .223 and sell the wrong ammo!
    > And of course, there's always the amount of powder that imparts the
    initial
    > velocity. Lot's of variables, but let's stick to a real .22 caliber (and
    > I'll give you a long rifle) bullet compared to a .45 caliber, and if I
    > absolutely HAVE to go into the woods where I might run into a bear, then
    I'd
    > prefer the .45 whether it's a talon or a hollowpoint.
    I'd go even chances going up against a bear with a loaded .22 or
    pistolwhipping with an M1911A1.
    Glenn D.
  7. Archived from groups: rec.audio.pro (More info?)
    "Arny Krueger" <arnyk@hotpop.com> wrote in message
    news:fcudnRV4xcVoXBLcRVn-oA@comcast.com...
    > Common US military ammo is 5.56 mm, which is just a scosh over 0.25 -
    close
    > enough to .22, right?
    Nit: it's closer to .22 than .25. 5.56mm divided 25.4mm is 0.218898.
    Glenn D.
  8. Archived from groups: rec.audio.pro (More info?)
    news:jIadnXmy7u--VRLcRVn-iQ@rcn.net...
    How many tank battles between the two wars? Infantry fighting in the cities
    doesn't expend DU rounds. Compare the number of tank division fighting on
    both sides in each conflict to estimate expenditure of DU.
    Glenn D.
  9. Archived from groups: rec.audio.pro (More info?)
    news:7M6dnRmRkdP-VxLcRVn-qg@rcn.net...
    I'll agree that I would be more concerned with the dust than with the
    radioactivity.
    that
    > territory.
    Like dud rounds? I bet they're a greater risk of harm to the populace. Or
    the actual fighting, too.
    I'll bet you could poll 1000 tankers, and a vast majority they'd rather take
    whatever risk exists of DU poisoning over the risk of not killing the enemy
    with a first shot.
    goals.
    There's tungsten, but it's a lot more expensive and less effective.
    comprise
    that
    I think DU poisoning will be so far down the list of troubles. How many
    deaths have been projected for that compared to how many were caused by
    sanctions, the current conflict or Saddam's own actions?
    Glenn D.
  10. Archived from groups: rec.audio.pro (More info?)
    I can't dispute anything happening on the ground because I've beat feet on
    the ground in war. What I'm disputing is military and US policy that places
    US military in harms way, dispenses questionably toxic material in it's
    wake, and has minimal concern for the people it professes to want to
    liberate, not to mention the possible toll it takes on our own military and
    their families. Apparently policy doesn't care if there are less people to
    liberate, as long as someone gets liberated. The assumption, however, is
    that one person left standing because of our "help" is perfectly acceptable.
    My preference would be that MOST of the people we profess to try to liberate
    get liberated, and hence I wouldn't want to leave their homeland scattered
    with munitions of any sort or toxic materials that will effect their lives
    for decades to come.
    And I damned sure don't want my brothers in arms coming home to find another
    14 years before any recognition of any "syndrome" that may occur for
    whatever reason it occurrs, and I don't want them to be screwed out of
    proper facilities to have their wounds and syndromes treated somewhere close
    to the family support that helps speed recovery and acceptance of such
    tragedies as losing arms and legs and having to have an unprepared family
    suddenly take up the burden. Nor do I want them to return home with such
    disabilities and then run into the problem of finding that their jobs are no
    longer available due to their long forced stint in the service or because
    they can no longer perform the duties they had prior to their taking up arms
    for the protection of American citizens.
    You suggest that any additional deaths based on some of these speculations
    is far less than the deaths already tabulated, but what you're not
    considering is that, in truth, we'd be talking about ADDING these deaths to
    those that have already come.
    Time to stop suggesting that more death is for the good of the people. It's
    not. It's only good for the policies.
    Roger W. Norman
    SirMusic Studio
    news:b%Pjd.2538$R%6.467@news.cpqcorp.net...
    > radioactivity.
    > that
    > > territory.
    the
    to
    certainly
    we
    consideration,
    take
    enemy
    > with a first shot.
    > goals.
    > comprise
    > that
    by
    > Glenn D.
  11. Archived from groups: rec.audio.pro (More info?)
    I'll hold the wagers.
    Bob
    "Things should be described as simply as possible, but no
    simpler."
    A. Einstein
  12. Archived from groups: rec.audio.pro (More info?)
    I am not a nuclear scientist, but as I understand it, it is the exact
    opposite of that. The probability that any atom will decay during a
    particular time interval is independent of the probabilities of all
    the other atoms decaying. In fact, if my understanding is correct,
    the theory is that the probability of decay is independent of everything,
    i.e. it's truly random.
    To me, it's pretty clear that if the above assumptions are true
    (independent probability for each atom), then the time at which
    all atoms will have decayed is totally unpredictable. To see
    this, pick any time interval you want. You might typically see
    lots of decay events during this time interval. But it's clear
    that as you decrease the time interval, the chances of having no
    events during that time interval increase. (Imagine you pick
    1 nanosecond as your interval for a tiny chunk of some substance
    with a long half-life.) So there has to be, for any chunk of
    some substance, a finite time interval for which it's very likely
    that no decay events occur. Since decay events are random (i.e.
    follow an exponential probability distribution), they have no
    "memory", which means that after that time interval, you have
    not moved any closer to a decay event than you were. So, if
    there's a finite chance that a time interval can elapse and you
    can have no progress toward the end state, then the time it takes
    for the process to complete can never be predicted.
    Well, if by "entirely unstable isotope", you mean a substance where
    the probability that an atom will decay instantaneously is 100%, then
    yeah. But in practice, as far as I know the probability of decay
    over a finite time interval is always finite. Even when they make
    a tiny sample of Element 106 in the lab and it only exists for 0.1
    milliseconds or whatever before it decays, it still doesn't decay
    *instantly*.
    On the other hand, what is the probability that in the one-second
    interval after I hit th "send" button on this post, that all the
    atoms in some object (like my mechanical pencil) would decay?
    Well, based on the theory I've heard, I'd have to conclude that
    the probability isn't zero. However, because decay is pretty
    unlikely for each atom, and since the probability is pretty much
    independent, you basically just multiply all the probabilities
    together. Even if you had 100 atoms that each had a 50% chance
    of decaying in the next 1 second, you'd still only have a
    1 in 1,267,650,600,228,229,401,496,703,205,376 chance of them all
    decaying in one second. So, scaling that up to a mechanical pencil
    reduces the probability even further, and the probability that all
    of the atoms in the entire universe would all go at once is just so
    vanishingly small (although still theoretically non-zero), that this
    particular form of universe destruction is not a big worry. :-)
    Now, what did all this have to do with audio? Oh yeah, all that
    pesky background radiation creates noise. Darn that stuff!
    - Logan
  13. Archived from groups: rec.audio.pro (More info?)
    Which says that it will occur in some universe in which
    that's the only difference from those in which it doesn't
    happen. Actually it will occur in an infinite number of
    universes but the measure of such universes is
    infinitessimally smaller than the measure of those in which
    it doesn't. You'll be the one holding that pencil in all of
    them, though, so it can be said with absolute accuracy that
    you can count to ten and expect it to happen. Accurate for
    some of you, that is.
    Oh, that's the implication of the Many Worlds Interpretation
    of quantum mechanics. :-)
    Bob
    simpler."
    A. Einstein
  14. Archived from groups: rec.audio.pro (More info?)
    On 2004-11-08, Romeo Rondeau <romeo@oakwoodrecordingstudio.com> wrote:
    > OK, let me get this straight... We're trying to kill the guy behind the
    > plated armour... but in case he survives, we don't want him getting cancer
    > from the dust?
    We don't support the cause enough to justify killing people generations
    into the future. However, I don't consider a small amount of Uranium to
    be as big a problem as large amounts of other, less toxic, heavy metals.
    And nothing compares to unexploded land mines in farmland areas.
  15. Archived from groups: rec.audio.pro (More info?)
    On 2004-11-08, Scott Dorsey <kludge@panix.com> wrote:
    > That's a lot, but what sort of tonnage of lead?
    > I'm not saying uranium isn't bad for you, I'm just saying that lead is also
    > bad for you. And leftover land mines are really, really bad for you.
    Scott, you just about word for word expressed my sentiments.
    This is my last political post on this non-political group. My views
    are already held by others, and I thank you.
  16. Archived from groups: rec.audio.pro (More info?)
    news:_5-dnddOLooNRBLcRVn-sA@rcn.net...
    places
    Like going to war?
    > wake,
    'questionably toxic' dust; serious toxic (fatal, at least) kinetic and
    pyrophoric effects. That's the job of the military: kill people and break
    things.
    and
    > their families.
    So you'd sacrifice troops today to protect others in future from a possible
    ill effect?
    acceptable.
    I don't know where this comes from.
    liberate
    So lead for bullets is out, then?
    another
    I agree. But taking away weapons like DU penetrators increases the number
    that won't be coming home. Given a choice between first kill hits on enemy
    armor and the remote chance that someone will contract something down the
    line, I'll keep DU. And so will the tankers, and the grunts protected by the
    tankers. You've been in service; how many of your compatriots smoked? When I
    was in fifteen years ago, it was nearly 80%. What's riskier, smoking or the
    chance of long term illnesses caused by the chance of DU exposure, which may
    or may not cause damage in any particular person?
    to
    Agreed. But given the opposing forces that our troops would have to face in
    future conflicts, I don't want to take away from their efficiency and
    survivability to avoid issues like DU.
    It's
    > not.
    Sacrificing more of our troops should not be a goal, either.
    Glenn D.
  17. Archived from groups: rec.audio.pro (More info?)
    "Nmm" <voxman@arvotek.net> wrote in message
    news:d1a1b33a.0411081304.27132dc9@posting.google.com...
    > "Romeo Rondeau" <romeo@oakwoodrecordingstudio.com> wrote in message
    news:<10ou5f9lhmtk2d3@corp.supernews.com>...
    > > > It's OK until you fire it down a gun barrel at high velocity and then
    > > > bang it into armor plating. Some of it tends to get finely pulverized
    > > > and oxidized. If you inhale the dust, that's bad. Worse than lead, in
    > > > that respect, because it's more toxic.
    > > > So you don't want to be on a battlefield where it's being used. Come
    > > > to think of it, you probably don't want to be on a battlefield,
    > > > period. As a turntable weight, it's probably as safe as lead.
    cancer
    > > from the dust?
    > No you don't want your guys getting cancer/ gulf war syndrome,
    We don't want our guys getting blown-up-in-the-tank syndrome either. That's
    why increased protection and first-shot kills are important.
    > and
    > everyone in a 1000 mile radius getting cancer/ gulf war syndrome.
    My, what a boogyman you've turned this into. Just how much uranium oxide
    dust is lying around, and how much does it take to cause problems?
    > Right now the Iraqi counterinsurgents are not behind any plated
    > armour anyway.
    And we're not shooting DU rounds at soft targets, either. HE or API, or even
    solid shot, is the weapon of preference for those targets.
    Glenn D.
  18. Archived from groups: rec.audio.pro (More info?)
    "Glenn Dowdy" <glenn.no.dowdy@hpspam.com> wrote in message news:<DjRjd.2552$cf7.1000@news.cpqcorp.net>...
    > cancer
    > > > from the dust?
    And for all the Tank to Tank battles that were fought in Iraq?
    Did the Iraqis even use tanks? Teriq Aziz told us before the war
    started that they weren't going to fight this on conventional means.
    > > and
    http://www.thepowerhour.com/articles/du_effects.htm
    The long-term effects from over a decade of DU exposures are emerging
    in Southern  Iraq. They are devastating. The increased  quantities of
    radio-active material ( including non-depleted uranium), used in
    Afghanistan are 3 to 5 times greater than Iraq 199.  In Iraq 2003
    they are already estimated to be 6 to 10 times 1991 and will travel
    through a larger area and affect many more people, babies and
    unborn.  Countries within a 1000 mile radius of Baghdad and Kabul are
    being affected by radiation poisoning , that includes the Capital,
    New
    Delhi, where the ruling elite lives.
    Somewhere in that article they also mention Iraq's 600% increase in
    child Leukimia,
    > > armour anyway.
    > Glenn D.
    Well they were straffing Al Fallujah all day today from F-18s. That's
    an M-61 Cannon that fires DU shells as far as i know.
    They are also using field artillery. DU is the preffered shell in
    Howitzers.
    A-10 Warhogs?
  19. Archived from groups: rec.audio.pro (More info?)
    Absolutely NOT so !
    http://www.phobe.com/s_cat/s_cat.html
    Graham
  20. Archived from groups: rec.audio.pro (More info?)
    Not for long ! As in, I doubt they even got a shell fired.
    The 'digital battlefield' wipes them out pretty fast.
    Graham
  21. Archived from groups: rec.audio.pro (More info?)
    << A better solution, although far more
    expensive, is explosive shielding, which immediately reacts to an attempt at
    penetration and explodes to counteract the kinetic energy of the offensive
    weapon. >>
    I did the post for a General Dynamics project about how to install GD Reactive
    Tiles onto Bradley assault vehicles. Talk about fighting fire with fire!
    Joe Egan
    EMP
    Colchester, VT
    www.eganmedia.com
  22. Archived from groups: rec.audio.pro (More info?)
    >See?...Do not argue with a rocket scientist. Scott really is a rocket
    >scientist, and people would be wise not to try to argue on knowledge
    >with him.
    Funny thing is he was responding to a post by George...so we know no real
    arguement will result.
    So Scott..how do we aquire some of this depleted Uranium?
    John A. Chiara
    SOS Recording Studio
    Live Sound Inc.
    Albany, NY
    www.sosrecording.net
    518-449-1637
  23. Archived from groups: rec.audio.pro (More info?)
    >>with him.
    That is correct John,
    I rarely bother to argue
    I point out facts and let others take it from there
    george
  24. Archived from groups: rec.audio.pro (More info?)
    Nmm wrote:
    > "Glenn Dowdy" <glenn.dowdy@commiecast.net> wrote in message news:<NL6dnTxexKU4vhDcRVn-vg@comcast.com>...
    >> Fix the Sudan problem. You have all the answers.
    > I really wish i knoew the solution or even the cause of the problems
    > in Sudan.
    Try this word:
    Oil
  25. Archived from groups: rec.audio.pro (More info?)
    >> in Sudan.
    Beer is the cause of and solution to all lifes problems
    Homer
Pro Audio Audio
