Tom's Hardware > Forum > Audio > Pro Audio > Mixing Audio-Tracks with fixed Volume Ratio?
Forum Audio : Pro Audio - Mixing Audio-Tracks with fixed Volume Ratio?
Archived from groups: rec.audio.pro (More info?)
Greetings!
I am quite new to Audio-Editing on PC, so this might be an easy task
to perform, but I don't get it right:
I want to mix two Audio tracks, both stereo, in a manner, that eg.
track2 is mixed under track1 always at say 10% volume of the actual
volume of track1 at the moment. The effect would be, that in low
volume passages of track1, track2 would be lower, too and the other
way round.
Is there an easy way, and software to accomplish this task?
Thanks for answering in advance,
Greetings, Hugo
Sponsored Links
"Hugo" <hugo3@freemail.hu> wrote in message
news:2bd34396.0411070734.1b4175c2@posting.google.com...
> Greetings!
> way round.
What software do you have?
jb
Reply to Anonymous
> Greetings!
> way round.
One way to accomplish this, is to use volume envelopes. For example
Audition/CEP and a number of other multitrack editing software products
allow you to literally draw lines that set the gain for each track at all
points along that track.
Since the tracks don't usually have the same relative loudness at all times,
the volume envelopes you would draw to do what you want, would probably not
be parallel.
Reply to Anonymous
"reddred" <opaloka@REMOVECAPSyahoo.com> wrote in message news:<0L6dnTze4uOlSxPcRVn-jA@adelphia.com>...
> jb
I don't have any multi-track recording software, jet. I wanted to ask,
which one would be the easiest to use and how it is done with that
particular software.
Greetings, Hugo
Reply to Hugo
As Arny stated, with automation it can be as easy as a mouse click and drag,
then go back and see if you did what you wanted. If not you do it again until
you get it right. All of the pro software's are like this, I have Peak LE in
which you have to high light the audio and do "change gain" in a drop down
file.
Needless to say I don't do any multi track editing or automation with that
program just overall mastering type stuff, I do tracking with DP3.
Reply to Anonymous
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
