Closed Solved
Wireless g Delivers Faster Broadband Than Wireless n
I have a Netgear WNR3500L wireless router. I assume it's v1 because on the back it doesn't have "v" anything. :-) Firmware version V1.2.2.44_35.0.53NA.
When I connect using g I get 22+Mbps download speed. When I connect using n I get 10 Mbps. I've tried using both WPA2 only (laptop reports 130 Mbps connection I believe) as well as the combo WPA+WPA2 (laptop reports connection of 117 Mbps). Broadband download results don't change - they stay at the 10 Mbps level.
I've fiddled with some of the settings on my laptop's wireless card - but the results are the same.
For now I'm just trying to figure out where I should focus my investigation and fiddling efforts - on the laptop or on the router.
Thoughts?
Thanks.
Jim
5 answers Last reply Best Answer
More about wireless delivers faster broadband wireless
  1. I thought I'd post a follow-up before others put effort into this...................
    I did the same test using a different n-capable laptop: Exact. Same. Results.
    The issue seems to be with the router. I find this quite surprising. This doesn't seem like it's something that should be stretching the capabilities of a/this router.
    Jim
  2. Best answer
    Most likely interference from another network either on the same channel or on an overlapping channel. Only 3 channels do not overlap (1, 6, 11) and everything is defaulted to channel 6.
  3. You did it. Changed to Ch 11. 23+Mbps.
    Thanks a lot!
  4. Best answer selected by Area51reopened.
  5. This topic has been closed by Area51reopened
Connectivity Wireless Laptops Connection Wireless Networking
