Tom's Hardware > Forum > CPU & Components > Sound Cards > multiple sound card ISSUE !
Forum CPU & Components : Sound Cards - multiple sound card ISSUE !
Can anyone help?
I am trying to use multple instances of windows media encoder on 1 computer. version 7.1 ( i cant use 9 ) requires a sound card for each instance even though i am not using it. does anyone know of a cheap sound card that its drivers will support multple cards in the same windows me computer? OR even better soem softwear sound card simulator so I dont even need a sound card.
Thanks
zac
Sponsored Links
I am trying to use multple instances of windows media encoder on 1 computer. WHY??? What exactly are you tryin to do??? Be more specific.
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.
Reply to 4ryan6
humm, details. ok
I have 4 cameras that i wish to stream at the same time. these camarea are usb cams and that part works fine, however media encoder 7.1 cannot just stream video without audio and each encoder looks for a sound card, thus the reason i need to put 4 sound cards in the computer.
Reply to cbl
What you doing Porno and need all those cams and audio! hehe
So you are doing this live? I do not think you can put 4 sound cards in one computer and have them not try to be the default one.
What are you outputting to? Maybe better software. You may have to network 4 computers! hehe
the Prisoner
I'm not a number, I'm a free man! :mad:
Reply to the_Prisoner
There are 1134 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
