MN 500 problems please help
Forum General Networking : General Gateways, Routers and Firewalls - MN 500 problems please help
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I have the 500 series base station, adapter and laptop
adapter, yet when I try to open the base station
management it wont let me, so i tried using the
192.168.2.1 and that wont work either, any help?
Sponsored Links
If you goto the command prompt and type "ipconfig" what ip is assigned to
your wireless card (or network card).
If it starts with 169.254.*.*, then it is not getting an ip from the base
station.
You might want to see if the network adapter is properly installed (check in
device manager)
Also see that you don't have mac filtering settings blocking your network
adapter (i.e. make sure they are correct)
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"T" <tber52@hotmail.com> wrote in message
news:ade601c436dc$0f5b4040$a401280a@phx.gbl...
Reply to Anonymous
I get the same problem... it's greyed out... I have to
close that window, then open it back up and click on it
real quick before it greys out again... seriously!!!
>-----Original Message-----
Reply to Anonymous
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > MN 500 problems please help
There are 787 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
