ViewSonic VX922 monitor - black screen - green power light flashes
Recently I upgraded to a new computer, working with Windows 7. Does my present ViewSonic VX900 monitor work with Windows 7 or is there a program that is available for downloading?
3 answers Last reply
More about viewsonic vx922 monitor black screen green power light flashes
  1. Hello Glad;
    Windows 7 doesn't much care what brand/model monitor is attached.
    You should at least get a basic display.
    Did you have more than one option on where to plug in your monitor? Which did you choose?
  2. if you are using a vga connector, make sure the pins are not bent. when you first turn the computer on you should see the computer POST screen. if the picture goes out after that it is possible the resolution set in windows is too high for your monitor. this can be fixed in safe mode.
  3. WR2 said:
    Hello Glad;
    Yes, I had a couple options for plugging into a USB port. I choose to use one at the back of my computer, instead of using one from the front. Worked great!
Configuration Viewsonic Windows 7 Monitors
