my HP puter is a pent4-2gig,w/1024sdram,it had a nVidia G Force mx/200 & I upgraded to a GeForce4-ti-4400/128mb/ddr/ram,& soon after the monitor(envision15"LCD)went nuts & the pc quit,took it back & was told the mother board was bad,had it back 1 month & BOOM same thing,put the orig. video card back in & took it back again,was told again the motherboard(AsusP4b-la)was bad,everythings been fine for 5 months w/ the orig. card.My powersupply is a 185w-200max so I figured the new card was using to much power as the box said 300w-350recomended power supply, but HP told me not to change the power supply or I might blow it up,so now I have a $300.00 card I'm scared to use! any sugestions???I'm still learning so I dont mean to sound dumb,thanks,Rob oops forgot this the processer is Intel & the chipset is a Intel 845
specs are:
Asus P4B-la mobo,1024mbsdr,slot is AGP,dvd rom,dvd r/rw/cd/r/rw combo,(AGP is 3.3v?)creative Extigy/24bit/100db snr/monsoon 5.1 suround speakers, thanks in adv. Rob<P ID="edit"><FONT SIZE=-1><EM>Edited by RobertSMoore on 11/30/02 01:54 PM.</EM></FONT></P>
Sponsored Links
185-200W is definitely too little. Your will need a new. If your PSU is a standard ATX power supply there should be no problems opgrading it. However, some machines by HP and DELL (and probably also other manufacturers) does not use a standard ATX supply (the pinout of the power connector differs). In that case you will need an original PSU.
Make sure you get the right one.
<i><b>Engineering is the fine art of making what you want from things you can get</b></i>
<A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=655" target="_new">My systems</A>
Reply to HammerBot
thanks Hammer,I'll pull the side off & check the dope on the power supply box
Reply to RobertSMoore
- 0 +
You cannot tell by looking at the PSU. Dell uses exactly the same connector but different wiring and their PSU is not compatible with ATX.
Reply to upec
Hammer wasn't completely accurate. While Dell uses a nonstandard power supply, HP uses an ATX power supply and ATX boards. The only difference is the size of the power supply housing, which is shrunk to fit the shorter HP case. So in order to replace the power supply with a full sized unit, you'll likely be left replacing the case as well. Newegg has a nice small Chieftec unit that's only slightly larger, and comes with a 450W PS, for $55. They also have several other nice cases you might want to look at, the black Inwins look awesome (my friend just bought one).
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
That's just Dell, dude, not HP. HP uses micro ATX boards and smaller form factor ATX power supplies.
Reply to Crashman
Thanks for the correction. I just re-checked my HP Vectra and it has a standard pinout. I must have missed something the first time I checked it.
Reply to HammerBot
thanks crashman, but will increasing the power supply damage the mobo,like HP said it would? thanks pard, Rob
you'd think with what I've been reading in here-with all the stuff I've got running (I'm maxed out inside) the power supply would shut down or at least I'd get a warning from within. My cpu temp is running about 35c & out here in the desert in summer its worse! so I shut it down in the afternoon, I've been looking at new cases & there are some awsome jobs out there, leaning toward the aluminum ones but need to do some more reading, with a trick flame paint job, round IDEs clear side panels,neon lights,crap here I go again!!
<P ID="edit"><FONT SIZE=-1><EM>Edited by RobertSMoore on 12/01/02 12:27 PM.</EM></FONT></P>
No, that would be impossible according to a basic law of physics, which is the basis of electrical theory, V=IR (is that Ohm's law or Amphere's law?), which states that for a given voltage and resistance, amperage will be the same no matter how big your power supply is. If an undersized power supply is used, the voltage will drop because of the lack of adequate amperage, maintaining V=IR.
Reply to Crashman
V=I*R is ohms law (The voltage is sometimes also denoted U). Ampere's law relates the magnetic field in space to the current in a conductor.
Reply to HammerBot
Ah, there you go. It's been a long time for me! Anyway, the law does show that you will use a given amount of current for a given resistance at a given voltage. So that oversized power supplies will not "overpower" a computer.
Reply to Crashman
Right, the PSU is a voltage source. The amount of power drawn is given by P=U*I. A more powerful PSU simply means its capable of delivering a higher current. But that higher current only runs if the resistance is small enough.
Reply to HammerBot
Yep, a component will only 'draw' the current it needs. So if your power supply can supply 30A but you only actually need 25A, you will only draw 25A, not 30A. The PSU controls the outputted voltage but the load (in this case your computer) controls the current draw.
Reply to tombance
NO. Its impossible for the power supply to supply too much power. The motherboard and all components only draw as much as they need.
P.S. 35C is very good for a cpu temp. You should only get worried if it gets to 65C or more.
<b>Just because someone's a member of an ethnic minority doesn't mean they're not a nasty small-minded little jerk. <i>Terry Pratchett</i></b>
Reply to lhgpoobaa
thanks Ihgpoobaa, it was getting around 50c/51c this summer,someone told me I have a warning buzzer or something like that in here that'll let me know when things get to hot, I have been looking into different types of fans,just read the one that has the magnets on the ends instead of a center motor,they claim a 30 percent decrease in the cpu because the center spool is smaller
Tip driven fans are ok i guess, but the dont spin as fast as standard ones, and ive only seen 70mm varieties.
Plain fans work for me.
Reply to lhgpoobaa
Tom's Hardware > Forum > CPU & Components > Other Components > power supply
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
