Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > Flash Ultra66 Problem
Forum CPU & Components : Other Components Flash Ultra66 Problem
I am trying to flash a Promise Ultra66 Bios to a FastTrack Bios. The flash program says the file is incorrect and will not flash. Has anyone had this problem and found a way around it?
Thanks
Brunix
Reply to Brunix
I would hazard a guess it aint working because they are two different things!
<b>Just because someone's a member of an ethnic minority doesn't mean they're not a nasty small-minded little jerk. <i>Terry Pratchett</i></b>
Reply to lhgpoobaa
- 0 +
There are at least 5 different sites guiding this modification and all say to flash the bios first. I have email the authors of the articles and found that their email address are dead or bogus. I have not emailed Mr. Pabst as he has a form for such problems. It is an old tweak. There is a how-to here that was written mar-29-2000.
Patience
Brunix
Reply to Brunix
- 0 +
I readed the changing part in the article and now I understand what you're trying to do.
I guess you're trying to flash the BIOS from a DOS/Win9x boot disk.
I would double check if you have exactly the right BIOS and flash utility. If you're using a pre made BAT file to flash the BIOS check if the BAT file has the correct file name into it. Also check you're using capital leters right if there are any in the name of the BIOS file.
My CPU runs so hot the arctic silver undergoes nuclear fusion :eek: .
Reply to svol
- 0 +
Thanks for the look svol :^) Yes I used a 98/command disk. The PTIFLASH let me make a backup if the original bios but said that the flash I wanted to use was not the correct file. I am thinking it is a tweak promise made to the bios file to stop this mod. I am hoping to find someone who has done this and still has the original bios file. I have three different ft bios file and none of them will take.
Brunix
Reply to Brunix
- 0 +
I got the flash to work with the info from http://www.tweakhardware.com/guide/raid66/
He had the missing option /Unlimit
<b>Brunix</b>
Reply to Brunix
There are 1454 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 4 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
