My PC has recently developed a problem with sound. I have a self built system, K6-2 @ 500MHz (I know its old, but I cant afford to build a new one yet), 192 Mb SDRAM, Geforce2mx400 64 Mb, ALS4000 sound card. The 2mx was installed only a week ago, upgraded from ATI Rage 128. The first problem noted was in Media Player, when putting the visualizations in full screen mode(in Ambience vis) the music actually slows down. Its like a casette being played slightly slower than it should be. Go back to the window, and the music returns to normal speed. Use the Plenoptic vis, and the problem does not occur. I was prepared to leave this, but then... Playing Commandos-Behind Enemy Lines, the sound effects had what can only be described as a warbling effect, and the the sound crashed to an interference sound like you get on a radio not tuned in, and the the same on a demo version of Harry Potter, and also now this warbling sound has appeared on Serious Sam, but not nearly as bad as on the others. I am going to try a new sound card in about two weeks in case that is the problem. But this has all started since the 2mx was installed. I have the latest detonators from Nvidia, and directX8.1b. I would really appreciate some ideas. Also I have recently adjusted some BIOS settings, such as stepped up the memory to Turbo mode and enabled the external cache and more. The K6-2 is not and has never been overclocked. I am thinking to try a hardware accelerated sound card, maybe a Sounblaster Live 5.1 ? What do you think ?
