I am now thinking I am a complete idiot I am following the instructions in the booklet. When I get to Setting up IP address manually the booklet states-Type IP address is 192.168.10.x (x is from 2-254) Do I use any number from 2-254 or do I use my Ip address. When I have tried both options I receive a Warning message- Multiple default gateway are intended to provide redunancy to asingle network (such as intranet or the internet) They will not function properly when gateways are on two separate disjoint networks. Do you want to save this config. I then hit No.
I have seen a video on You Tube showing how to install this item and he seems to disconnct the router at this stage. Can anyone help this complete dummy. Me......
