Mobile PhoneTools doesn't find my V551 phone....help!
Archived from groups: alt.cellular.motorola (More info?)
I purchased Mobile PhoneTools with the Motorola Bluetooth adaptor and
am trying to set up my V551 but, mobile phone tools can't find my
phone. If I go in under the microsoft program it can locate the phone
but MPT can't in the set up stage, can any one help me set this up?
2 answers Last reply
More about mobile phonetools doesn find v551 phone help
  1. Archived from groups: alt.cellular.motorola (More info?)
    Make sure that you've run Live Update in MPT to get the latest version
    (3.19e) and also start the program first before you make the phone
    discoverable. You have to turn on BT power in the phone and then, under
    setup, select "Find Me" so the PC can see the phone.
    You might also want to read the posts at: http://brobin111.blogspot.com
    saeaster@verizon.net
  2. Archived from groups: alt.cellular.motorola (More info?)
    Thanks, I found the answer. There is a problem with MPT and SP2 once I
    went to the help site it walked me through the solution.
Motorola Mobile Phones
