Issues with wireless/router after reset.
December 28, 2012 1:34:49 AM
Hi, i recently was having some connectivity issues with multiple xbox's connected to our one router. I was told by enabling UPNP it might fix the issue of the separate systems connecting at the same time.
My problem arose when attempting to connect to my routers setting using the default login and password to enable UPNP. They were shown as incorrect.
So i was told by factory resetting the router it would in turn reset the username and password allowing me to log in, after doing the reset i was left with the incorrect message still happening and no wireless internet to speak of. I think that after the reset my wireless was left not configured but i cant access the router settings to change that because of the password not resetting.
I would greatly appreciate any help, and apologize in advance for my vague information due to my lack of knowledge.
Router: Motorola SBG6580
ISP: Bright House Networks
