OK i have been searching the web for 3 days now. All i would like to do is add another power supply to my computer because i have an extra one. The only problem is that i don't know how to get the extra one to turn on when i turn the computer on. I think that i have to do some wire splicing with the 20 pin connector to the motherboard. But that is the problem, which wires do i do that too? Or if someone could just tell me how to do this in plain english that would be very helpful. I have a p4 board if that makes a difference because of the p4 4pin connector. But please some one help me out here, i am dieing here. Thanx
<A HREF="http://www.ipv7.net/hwb/connector/power/atxpower.html" target="_new">http://www.ipv7.net/hwb/connector/power/atxpower.html</A> I think you only need to spice the power on and a ground wire.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
You need to connect ground and pin 14 of the ATX power connector to ground and pin 14 of the other PSU.
The /PS_ON signal comes from the mobo and is used to turn the PSU on when the front power switch is pressed.
<i><b>Engineering is the fine art of making what you want from things you can get</b></i>
<A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=655" target="_new">My systems</A>
This is very easy. I also did it myself according this pic:
<A HREF="http://www.waterkoeling.nl/files/voeding.gif" target="_new">http://www.waterkoeling.nl/files/voeding.gif</A>
So you only have to connect the PowerGood wire with a ground and the Power On with his ground with the Power On and his ground of the other PSU.
My CPU runs so hot the arctic silver undergoes nuclear fusion .
