Archived from groups: alt.cellular.motorola (More info?)
I have a new V180 and have used the Motorola software to send MP3s as
ringtones and it works.
But I have one file that will not play. I can a 'file is corrupt' when I try
and play it. The MP3 is the sound from the TV series 'Emergency' when a
multiple alarm sounded in the firehouse.
If anyone wants to try it, email me, and I will send it to you. All I ask is
you send it back if you get it to work.
On Sun, 6 Mar 2005 10:58:59 -0500, "Dean S. Lautermilch®²ºº³"
I don't have a v180 so I can't help you specifically, but a few things
to look out for are most phones have a requirement for bitrate,
maximum size, and length. Perhaps the Emergency file is too short? Too
low or high a bitrate? too large?
Just some ideas...
Evan
To reply, remove TheObvious from my e-mail address.
Try converting it to a lower bit rate (28 or 30 kHz) and you'll probably
have better luck.
Fromean S. Lautermilch®²ºº³
> when I try and play it. The MP3 is the sound from the TV series
> 'Emergency' when a multiple alarm sounded in the firehouse.
> ask is you send it back if you get it to work.
I had to same problems, it was because I saved a wav file to an mp3
without the proper codec. Upload it to the group and I'll fix it for
you.
On Sun, 06 Mar 2005 17:36:51 GMT, "BruceR" <brNOSPAM@hawaii.com>
>have better luck.
"Evan Platt" <evan@TheObvious.espphotography.com> wrote in message
news:b9em21l3dn4jdksjm6f5s6jjap8ofciqrg@4ax.com...
>>try
>>is
> Just some ideas...
32K bitrate
22K sample rate
done using RazorLame software.
Worked fine.
Thanks for the suggestion.
Anyone wants the two files (mp3 and WAV) email me.
If you're under 40, it would be a meaningless sound.
In news:112nebdmq50lb69@news.supernews.com,
Dean S. Lautermilch®²ºº³ <ftlbard@nospam.bellsouth.net> typed:
> > > when I try
> > > ask is
> > Just some ideas...
> 32K bitrate
> 22K sample rate
> Worked fine.
Sure, I'd be interested (WELL over 40). Just delete the ... in my addy.
"F. Edwin Felty" <fef...@xrex.us> wrote in message
news:UNednawWac4cIbbfRVn-2A@adelphia.com...
>> > > when I try
>> > > ask is
>> > Just some ideas...
>> 32K bitrate
>> 22K sample rate
>> Worked fine.
the email was rejected by your server. Try another account and please email
me.
Damn the rules. Post it. whatta they gonna do, arrest ya?
"Dean S. Lautermilch®²ºº³" <ftlbard@nospam.bellsouth.net> wrote in message
news:112ma6tluu0s561@news.supernews.com...
try
is
