Tom's Hardware > Forum > Audio > Pro Audio > Which CD or DVD ROM drive is best for high-quality audio r..
Forum Audio : Pro Audio - Which CD or DVD ROM drive is best for high-quality audio r..
Archived from groups: rec.audio.pro (More info?)
I produce radio programs on my PC. This involves ripping tracks from
many, many CD's during a session.
In order to save wear and tear on my CD burner (a PlexWriter if you
must know), I want to get a CD or DVD-ROM drive to rip the discs and
leave the burner for burning. I understand however, that many CD/DVD
ROM drives which are perfect for data are inadequadate for ripping
CDDA (my extraction software says "resync required", which slows
ripping down considerably).
Which brands and models of drives have people in this forum used
successfully for ripping CDDA? Where can you get them?
Thanks in advance.
Sponsored Links
Plextor and Teac are 2 of the best CD ROMs
Paul <tungarbulb@yahoo.com> wrote in message
news:d6a862c7.0411281852.a3d14f6@posting.google.com...
> Thanks in advance.
Reply to Troy
"Paul" <tungarbulb@yahoo.com> wrote in message
Ripping tends to be a slower process. The most important thing is that your
rips are error-free. Of course they need to happen in a reasonbly timely
fashion. But that will vary, even with the finest drives, depending on the
condition of the discs you are using.
What kind of accuracy and speeds are you observing?
I've found that a wide variety of modern drives from quality providers such
as LiteOn, Asus, Pioneer, and others do error-free ripping at speeds in the
7X to 15X and higher speeds, which I deem adequate for my purposes.
Reply to Anonymous
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<QeSdncE-X-sNjjbcRVn-3Q@comcast.com>...
> Ripping tends to be a slower process. (snip)
Usually from 3X to 15X depending upon the media. Commercial CD's tend
to zip along faster than CDR's. Unless a disc is really screwed up,
I've not seen noticeable errors.
So IOW, you believe that any modern CD ROM drive will do? I had
"resync" problems with a 3-month-old Samsung CD-ROM drive (or is that
the problem right there)?
Reply to Paul
news:d6a862c7.0411291944.6216ef62@posting.google.com
That's pretty much typical performance.
> Unless a disc is really screwed up, I've not seen noticeable errors.
A good combination of ripping software and drive should provide zero errors
unless a warning or error message is provided.
>> providers such as LiteOn, Asus, Pioneer, and others do error-free
>> ripping at speeds in the 7X to 15X and higher speeds, which I deem
I wouldn't go quite that far, as I still find some cheapies that aren't very
good. Last example was a off-branded drive from a office supply store.
> I had "resync" problems with a 3-month-old Samsung CD-ROM drive (or is
> that the problem right there)?
What ripping software were you using? The standard tools are CDEX and EAC,
both of which are freebies.
Reply to Anonymous
Just to add to the discussion. If you're interested acheiving the best
quality, perhaps what might be considered audiophile quality, then the brand
and model of drive can make a difference; the speed of recording too. My
resources and experience are limited, but I've compared a number of drives
that I've owned in the past and present ( Lite On, Sony, Yamaha, Teac,
Philips, Asus and Plextor).
When I've burned at the slowest speed, usually 3x with Samplitude or
EZCDCreator software, it always sounded better than faster speeds if
comparing the results with headphones and a good headphone amp. The drives
are more or less transparent too. So far the two most transparent and best
sounding drives I have are the Plextor and the Yamaha I used to have, but
was destroyed by a bad switching supply a couple of months ago. The Philips,
the Sony & the Lite On result in a lesser quality, the differences being
clearly audible with good headphones. As to whether a given person can hear
that difference with their particular loudspeaker & audio chain, or that
they even care about such sonic minutia as that existing among the different
CDRWs available, that's another matter. I'd say that unless you're doing
audiophile stuff, then pretty much any drive is fine, though if quality is a
factor, try experimenting with different recording speeds & see what you can
get away with. I don't know about the underlying mechanisms, how to account
for the differences, but I know they exist because I've heard them. There
are probably web sites or others lurking on this newsgroup who could offer
some possible explanastions.
Good luck!
Skler
Reply to Anonymous
On Wed, 1 Dec 2004 20:31:16 -0600, "Skler" <antcopter@hotmail.com>
I think I agree with you, but I'm not absolutely sure I know what you
said...
The original question was about drives for ripping CDs. I haven't
directly compared drives in that situation, but I have definitely
compared their S/PDIF digital outputs and found them amazingly
different in sound, going into the exact same DAC. My all-time
favorite so far is a cheap Memorex IDE CD play-only drive. Its digital
out sounds way better than several supposedly fancier brands that cost
a _lot_ more. I have no idea if that has any influence on the data
available at the IDE connector, though. Does anyone know if S/PDIF out
is created from the raw data you get on the IDE port, or are both
created from some more primitive form?
Comparing analog audio outputs, the Yamaha (4X?) burner I used to have
was outstanding compared to any other drive before or since. It put my
stereo component CD players to shame! (But even it sounded nowhere
near as good as the Memorex S/PDIF run through my ART DI/O.)
So are you saying that, using one single known high quality playback
drive, you find repeatable differences in sound resulting from the
drive used to burn different CDs? Which of course introduces questions
of incompatibility between the two particular drives as well as the
quality of the burner...
Or are you listening to each burn on the same drive that recorded the
audio, adding differences in playback quality to the possible
differences in recording quality? When you say different recording
speeds make a difference, were you listening to the different CDs on
the same drive that burned them?
So many possible effects!
Loren
Reply to Anonymous
"Skler" <antcopter@hotmail.com> wrote in message
news:colupq$d92$1@geraldo.cc.utexas.edu
> the brand and model of drive can make a difference; the speed of
> recording too. My resources and experience are limited, but I've
> compared a number of drives that I've owned in the past and present (
> Lite On, Sony, Yamaha, Teac, Philips, Asus and Plextor).
> drives are more or less transparent too. So far the two most
> transparent and best sounding drives I have are the Plextor and the
> Yamaha I used to have, but was destroyed by a bad switching supply a
> couple of months ago. The Philips, the Sony & the Lite On result in a
> lesser quality, the differences being clearly audible with good
> headphones. As to whether a given person can hear that difference
> with their particular loudspeaker & audio chain, or that they even
> doing audiophile stuff, then pretty much any drive is fine, though if
> quality is a factor, try experimenting with different recording
> speeds & see what you can get away with. I don't know about the
> underlying mechanisms, how to account for the differences, but I know
> they exist because I've heard them. There are probably web sites or
> others lurking on this newsgroup who could offer some possible
> explanastions.
The explanation is pretty straight-forward.
There are some audio CD players that lack the broad media parameter
acceptance characteristics of a good modern optical disc player, and are
very sensitive to what should be trivial differences among CDs. Burned CDs
tend to have far more optical parameter variations (reflectivity, contrast,
and reflective surface smoothness, for example) than regular pressed CDs.
Reply to Anonymous
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<N4CdnbKKpuM05zHcRVn-2g@comcast.com>...
Yeah, I avoid those office store generics myself.
Hmm, I'll hafta check those software packages out. Where do you get
them? I've been using Easy CD Creator 5 on an older machine and Adobe
Audition on my newer one.
Reply to Paul
news:d6a862c7.0412030642.42c8ebd2@posting.google.com
>> aren't very good. Last example was a off-branded drive from a
>>> (or is that the problem right there)?
>> and EAC, both of which are freebies.
> them?
Search google - the author's web sites are typically at the top of the list.
Best thing I can say is that EZ 5 was an improvement over EZ 4.
>and Adobe Audition on my newer one.
I use that ripper a fair amount with newer Liteon DVD-R drives.
Reply to Anonymous
news:A_adnYyraLVjFi3cRVn-qQ@comcast.com...
I can unhesitatantly recommend Hewlett-Packard optical disk drives. ;)
Glenn D.
Reply to Anonymous
A digit is a digit, no?
So, are you merely saying that some audio CD players are unable to perform
100% error correction on some 'modern' CD-R/RWs?
m.
Reply to Anonymous
No CD players can perform 100% error correction. In part, this is because
the CD player is a streaming device... if there is a transient media
error, it can't go back and reread.
If you are ripping with a CD-ROM drive, you can go back and reread a block
over again if it's not good. But CD players can't do that because they have
to work in realtime with minimal buffering.
So, there is a lot of interpolation that goes on. If you have a couple hundred
uncorrectable errors on a CD, you won't notice the interpolation. But if you
have a couple thousand, you may notice some degradation. And that isn't
unusual for a CD-R.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Martin Tillman" <m_tillman@NOSPAMdsl.pipex.com> wrote in message
news:9bEsd.6229150$6p.989508@news.easynews.com
Once it is properly read...
> perform 100% error correction on some 'modern' CD-R/RWs?
That would clearly be the case.
Reply to Anonymous
That would surely depend on the severity of the error.
Again, that surely 'depends'.
A while ago I ripped a commercial CD using CoolEdit (not EAC, or CDex in
paranoia mode) and 'recorded' the same CD into CoolEdit via TOSlink using a
mid price CD player of about 15 years vintage. I was extremely surprised
(possibly due to ignorance) to find the two files were identical.
m.
Reply to Anonymous
Excellent. Glad to get confirmation neither of us are losing our marbles
yet.
m.
Reply to Anonymous
news:VuHtd.4325873$yk.651108@news.easynews.com
> marbles yet.
At least not *those* marbles! ;-)
Reply to Anonymous
There are 1109 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
