Solved
How to connect: wifi web to pc to wired to pc
Last response: in Networking
Best solution
Sure, Internet Connection Sharing (ICS) which you would enable on the wirless adapter and then just connect the two Ethernet ports with a patch cable (if at least one of the Ethernet adapters is gigabit) or a crossover cable if neither is gigabit. Gigabit comes with auto-MDIX so it senses the connection and uses the right one.
You can also bridge the Ethernet and wireless adapters on the laptop (but ICS must be off for that), simply open the network control panel, change adapter settings, highlight both adapters, right click and select bridge connections.
