I just received a Trendnet TEW-680MB in the mail. I plan to use it to connect my xbox 360 to my wireless router. My router is the Linksys Valet M10. The problem that I'm having is that whenever I enter the url address to access the setup wizard for the bridge, it doesn't connect. I'm not sure why because I have it connected to my computer via ethernet like the install guide says to and the lights on the front indicate that there is a 1000 mbps connection established with my PC (orange and flashing). My PC that I have it connected to is connected to the network/router via wireless connection and the PC is a desktop with high end parts.
Does anyone know what could be causing issues? I just want to connect to the bridge to be able to configure my wireless connection/security settings so I can use it for my 360...
