Tom's Hardware > Forum > Audio > Pro Audio > looking for schems to build 48 ph power supply
Forum Audio : Pro Audio - looking for schems to build 48 ph power supply
Archived from groups: rec.audio.pro (More info?)
I am looking for schemes to build 48 ph power supply which can work with
6-18 v dc range
its very important that it would work from 6 v
any suggestions ?
thanks all
Oleg Kaizerman(gebe) Hollyland
Sponsored Links
"Mike Rivers" wrote ...
> Are you sure you want phantom power with that voltage? There's an
> official phantom power of 12V and some mics are designed to work with
> as low as 9V, but with a range like that, you may be talking about a
> different (not phantom) power scheme like that used to power condenser
> mics in aircraft headsets. That applies the voltage across the mic
> wires (the single-ended center conductor and the shield) through a
> resistor, and a capacitor is used to isolate the DC from the powered
> microphone output.
> Phantom power applies the same voltage (referneced to ground or
> shield) to both leads of a two-wire microphone connection, and it's
> most commonly 48V.
Oleg knows what 48p is. (From reading about his years of
experiences on r.a.m.p.s) But indeed, it would be better to
have a few more details about what he is trying to do.
Reply to Anonymous
I need the main power would feed the phantom for the mike and will provide
the dc for lectrosonic transmitter or zaxcom gold line
that is a project I call phantom boom suspension holder which would be
placed between the mike suspension and the last part of my boom to
eliminate need to work with cable on the boom at all ( my boomen are all
drummer players so there is no big problem with extra weight :-))
Oleg kaizerman (gebe) Hollyland
"Richard Crowley" <rcrowley7@xprt.net> wrote in message
news:10qucbqc0j39k5d@corp.supernews.com...
>> microphone output.
>> most commonly 48V.
Reply to Anonymous
> >>6-18 v dc range
Marlin P. Jones & Assoc., Inc
10V to 20V in (+12V to 48V ) 48V out
http://www.mpja.com/productview.asp?product=15438+PS
$10.95
Reply to Anonymous
thanks
Oleg
"Port" <port@vintageproaudio.com> wrote in message
news:qK6dnWJwCcpDxDLcRVn-iA@comcast.com...
> >>6-18 v dc range
$10.95
Reply to Anonymous
In article <10qucbqc0j39k5d@corp.supernews.com> rcrowley7@xprt.net writes:
Oh, boy, did I misread that query! I saw the "48" part the second time
around, and the mention of a lower voltage range triggered an
experience I had recently with powering aircraft headset microphones.
Sorry for the misdirected reply.
I'd use a DC-DC converter, or a stock phantom supply and a commercial
inverter. No sense in trying to build something you can buy.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
Another simple example, much like Scott's idea but using inverters
as the oscillator, and "doublers" instead of a transformer:
http://paia.com/phantsch.gif
FWIW, the M-Audio Omnio i/o box uses this idea (with a 555 timer)
to get phantom power for their INA103-based preamps.
-Tom
To respond by email, replace "somewhere" with "astro" in the
return address.
Reply to Anonymous
One caution: all of the circuits called out so far will not meet the
P48V current specification. Many of them will struggle to put out 2 or 3
mA and then drop their voltage under the stress.
If you're using a mic that has a high phantom power current requirement
(e.g., Earthworks, Schoeps), these circuits will not work.
Len Moskowitz PDAudio, Binaural Mics, Cables, DPA, M-Audio
Core Sound http://www.stealthmicrophones.com
Teaneck, New Jersey USA http://www.core-sound.com
moskowit@core-sound.com Tel: 201-801-0812, FAX: 201-801-0912
Reply to Anonymous
There are 1079 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
