How can I go about checking the link speed of my wifi on my iPhone? Android devices show it as standard when you click on the network you're connected to and Windows shows it via Task manager/Wireless properties.
There is one called network Info 11, There's another called Internet speed test, but the one I was refering to is found on the Amazon app store and it's free and called Wifi Analyzer.
I can't find Amazon app store for iOS and the other two apps you mentioned aren't in App store either, am I doing something wrong?
You can't find the Amazon App store ? You go into the Android app store and do a search for Amazon app store and it's actually called Amazon app notifier.
