Connect Wireless Antenna directly input Router?
I am working in a library that has a wi-fi general availability.
My question is how can I use this existing wi-fi as input to a router to make a sub wi-fi for four computers and a wireless printer. Some of my computers may need to be wired into the router.
TIA
5 answers Last reply
More about connect wireless antenna directly input router
  1. The signal has to be wired into the wlan port on the router , a wireless router broadcasts the signal and doesn't pick up a wireless signal. You have to get an extender or repeater that will pickup the signal and then you can wire it into the router.
  2. inzone,
    Thanks for the reply. It provides me with needed information.
    PaulWarman
  3. Your welcome.
  4. Buy a Linksys WRT54G (~$40) and load DD-WRT on it. Then configure it to be a client bridge, like this: http://www.dd-wrt.com/wiki/index.php/Client_Bridged
    This will just give you 4+ wired ports off of one wired connection. You would need another radio (basically a second router) to make your own wifi network off of that connection.
    The real question is, why would you want to do this? What is the point of receiving the wireless signal and then re-transmitting it? It's going to create a lot more noise on the 2.4ghz spectrum than is necessary.
  5. I wish to thank all those who shared their expertise with me. I have learned a whole bunch of networking in a short period of time. When I went to the site that had the Wi-Fi, I found that the signal strength to the room that we have been assigned made it impossible to use a wireless setup at all.
    Thanks again to all that tried to help me.
    PaulWarman
Configuration Routers WiFi Computers Connection Wireless Networking
