Archived from groups: alt.cellular.motorola (More info?)
I see several cheap non-OEM data-sync USB cables for Motorola V551 on eBay.
The OEM cables are relatively expensive. Anyone used the non-OEM cables? Any
problems with the non-OEM cables?
On Mon, 4 Apr 2005 16:43:06 -0700, "Dummy" <shirish_patil@comcast.net>
yelling "The Guns, The Guns, Thank God the Guns" stated;
Its a hit and miss so far with mine. One time it works, the next it
doesn't or drops the phone during the session. I have ordered the OEM
cable in hopes I will have better luck.
The software is so bad its hard to tell whether the problem is in the
connection or the software. I actually accomplished my synch tonight
without problem, a first!
"Sarge®" <sarge@dontbother.com> wrote in message
newsf5451tdohos8gcmblbmjhug26e4ihum1v@4ax.com...
>>eBay.
>>Any
> Sarge®
> Member IPL, VAC, RCAA
> PGP Key 0x59DDC455
