I was wondering if anyone out there had been through this as well. I
own a pair of the events, having purchased them only this summer.
Everything seemed to be just dandy with them until I started to mix
some stuff I had recorded with a band. As I got into the mixes, I
started to feel like my mix was pulling to one side. I thought I was
tripping until it became painfully apparent that something wasn't
right.
Upon closer inspection, I noticed that my left monitor sounded
noticably different and softer than the other. When I slid single
instruments to one side or the other, I discovered that the "bad"
monitor seemed to have a tinnier sound...you know, not pushing as much
air, quieter, etc. Since then, I've tried all the usual stuff,
switching cable, switching monitors, switching outs, but all to no
avail. When I crank the trim on the back of the monitor to even it out
with the "good" one, the balance is better, but the sound still isn't
matched.
Could I have blown something? I do turn it up loud sometimes, but
nothing on the order of the Back to the Future guitar amp. The tweeter
seems to be fine; if anything, it's the main speaker not giving me the
loudness and fullness of the other one. If anyone has any advice or
experience with this same problem, I sorely need your expertise, as I
am working with some artists this week and I'd love to suss it out
asap. Thanx.
> right.
> matched.
> asap. Thanx.
Have you tried contacting Event? That would be my first suggestion.
>> matched.
First swap the monitors and make sure that the problem is with the monitor
and not the cable or room.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
In article <1102422544.808663.196150@c13g2000cwb.googlegroups.com> holyspicoli@hotmail.com writes:
Which ones? Powered or unpowered? And if unpowered, what are you
driving them with?
Yes, but first swap the left and right inputs to make sure the problem
is with the speakers and not with a cable or something on that end.
You need to isolate the problem and you have to do that
systematically - change one thing at a time, don't just stab at it.
You may not be able to fix what's wrong, but you should know where the
problem really lies so you'll know what needs to be fixed.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Thanx for everybody replying. Yep, I had tried all that stuff. But if
no one else has had similar issues with Event monitors (powered 6 in.
Studio Precisions BTW), I'll just get in touch with the company. Thanx
again.
