Tom's Hardware > Forum > CPU & Components > Other Components > Sufficient Power Supply?
Forum CPU & Components : Other Components - Sufficient Power Supply?
Hey, I'm going to build myself a new computer with a ASUS A7N8X mobo, 2 x 256 mb DDR400, and a Radeon 9700 pro in it. The case that i'm buying has a 350 watt power supply. I was wondering is that enough power for my system?
Sponsored Links
It should be fine.
Reply to upec
Unless you run 3CDROMs and 3-4HDs and many casefans it will be enough.
My PC eats so much money that I'm in 'desperate' need of it to buy PC3500 RAM, help Svol with his OC project!
--- PM me for information.
Reply to svol
Well, I'm going to have 2 DVD/CD drives and 2 harddrives in the case. Plus the 9700 pro is a power sucker. Is the 350 watt power supply still enough? Even if i want to overclock the 2800+, is the 350 ps sufficient?
Reply to SaiyanX
Without OC I think it will be enough. But when you start OC'ing it could be that you need a better one. You just have to try to see if it supplies enough power when you start OC'ing a bit.
Reply to svol
350W should be sufficient, provided its a quality brand like Antec, Toptower or Enermax.
Though you may need more for really extreeme overclocking. (unlikely though)
<b><font color=purple>[Rik_]</font color=purple> I wonder how many people have made their own phasechange system?
<font color=blue>[LHGPooBaa]</font color=blue> I get phasechange whenever i eat a hot chillie :lol: </b>
Reply to lhgpoobaa
if you play on upgrading certain parts, that might need more power... then i'd save yourself the trouble and just go with a 431w Enermax for safekeeping
This Community is like a Second Family!!
Reply to Rob423
There are 972 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
