I'm mostly inclined to view products like this as pure snake oil, given
that they're marketed to the same crowd who swear by $500/foot speaker
cables, exotic isolation platforms for power amps, green Sharpies for
CD edges...products whose justification is based on psuedoscience,
hearsay, expectation bias, and the sheer gall of marketing hucksters.
But then I remember that nearly every tube guitar amp I've ever owned
has gone microphonic at one time or another. So maybe Tube Dampers
aren't such a dumb idea for a Pultec...anyone?
Buster Mudd <mr_furious@mail.com> wrote:
>Anyone use Tube Dampers (eg, something like these:
>http://herbiesaudiolab.home.att.net/index.htm) in their tube mic
>preamps or equalizers?
For the most part, I don't think these will be very effective. But
mounting tubes out on shockmounted sockets, combined with adding some
rigidity IS very effective at reducing microphonic noise. The thing
about microphonics is that damping down the tube envelope won't do
too much because most of the noise is from the grid itself moving around.
Note that if these things do work, spring-mounted tube shields will do
basically the same thing.
For the most part, tubes that go microphonic are due to the mica insulation
or internal supports being damaged from the expansion and contraction, allowing
elements to start moving around inside. The best solution for this is slower
startup and shutdown. Most amps were designed when tubes were cheap and
expendable so nobody bothered with things like thermal relays for delayed
startup because they were more expensive than just changing tubes occasionally.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
I've seen equipment where the tube socket itself is mounted on rubber
washers. It was a tape deck, and I think they were the EF86s for the
tape head preamp. That would be more effective for stopping vibration than
attaching things to the top of the tube.
Not totally psudoscience IMHO. Even digital gear sometimes makes little
noises on the output if you hit the case....
On 8 Dec 2004 11:16:05 -0800, "Buster Mudd" <mr_furious@mail.com>
Presumably your rack gear isn't going get vibrated like a guitar amp
does. I wouldn't see a need for tube dampers unless you have your
gear sitting on top of a speaker cab.
My ancient Ferrograph has just that arrangement. Along with the screening can
with the spring retainer.
I must try tapping a D-A tomorrow ! But then there'll probably be some
mechanical noise pickup from the nearby output filter. Oh well...
I've done a whole lot of experimentation with tube damping devices in preamps & amps, and I can
say two things about them:
1) Elastic damping rings pretty universally tighten up the bass substantially & clean up the
mids a bit, with these effects being more pronounced in power amp input/driver stages than in
preamps, but still quite extant in all cases.
2) No damping rings were more effective than the simple silicone o-rings available dirt cheap
at mcmaster.com, where they are sold for plumbing & etc. For example, on 12AX7-size tubes, I
use 1"o.d./0.75"i.d. & use two or three per tube(3 or 4 for tall ones like the 12BH7 & 6CG7).
This o-ring is about $15 for a bag of 50. Being silicone, they don't dry out or crack like
neoprenes, and don't melt all over the tube & socket like the sorbothane rings(which seem to
have thankfully disappeared from the market). And they're cheap enough that even a small
benefit potential makes it worth using them.
Stephen Sank, Owner & Ribbon Mic Restorer
Talking Dog Transducer Company
http://stephensank.com 5517 Carmelita Drive N.E.
Albuquerque, New Mexico [87111]
505-332-0336
Auth. Nakamichi & McIntosh servicer
Payments preferred through Paypal.com
"Buster Mudd" <mr_furious@mail.com> wrote in message
news:1102533365.889034.213640@c13g2000cwb.googlegroups.com...
Pooh Bear <rabbitsfriendsandrelations@hotmail.com> wrote:
>Scott Dorsey wrote:
>> How about mechanical feedback from speakers in the same room? I could imagine
>> if tubes were slightly microphonic and they were in the room with some large
>> speakers that there could be bass coupling going on.
>I guess that would introduce an error signal and make the bass sound underdamped and 'wooly' like a PA
>close to feedback. Sounds plausible. A limitation of tubes to be honest. I can't see teflon rings
>helping all that much here since it's not the glass envelope that's the direct pickup mechanism. You'd
>need to 'decouple' the entire tube from the source of vibration - hence anti-vibration sockets ! Which I
>noted I couldn't easily find using Google. So much for the tube audiophools.
Yes, I have done the rubber shockmount thing for nuvistors a lot, because
the tight spacing on them makes for more microphonic issues than most
tubes. Teflon rings wouldn't do much, but I could see hanging a large mass
on the envelope at least changing the tuning of whatever mechanical
resonances are there a little bit. Maybe not much, since most of the problem
are the grids wobbling around with respect to the cathode and plate.
The anti-vibration sockets were common in military gear, and Fair Radio
probably still stocks them somewhere. Don't let the audiophile crowd know
or there will be a rush on them.
>Much simpler to use solid state !
I am having a very bad surface mount experience today. At least when tube
gear fails, the parts have the values marked on them....
--scott
tube
> --scott
Oh yeah, nothing like tring to desolder, test and replace a flat
trasistor the size of a gnat. Fun Fun Fun
A gnat would look like Godzilla compared to some of the new ultra-tiny SMD transistors in use
nowadays. Incidentally, there is at least one "decoder book" available for the inscrutible
numbering system on those things. I think I saw it in the Parts Express catalog, or maybe MCM.
505-332-0336
<tymish@hotmail.com> wrote in message
news:1102692918.665634.270560@c13g2000cwb.googlegroups.com...
> tube
> > --scott
In article <cpcjvq$ogr$1@reader2.nmix.net>,
The numbering on resistors isn't so bad, but I have a whole stack of boards
with tantalum decoupling caps that are just brown rectangles with no numbers
of any sort. At least I _think_ they are tantalum decoupling caps...
they are certainly failing like tantalum caps.
--scott
