Closed Solved
Offline printer problem
What does printer offline mean? My printer was working and now says print is offline....HELP SOMEONE PLEASE
8 answers Last reply Best Answer
More about offline printer problem
    Means your computer can't see you printer.
    You are painfully short on details. Firstly, when/what happened that you noticed your printer was "offline".
    Next, how is the printer connected to your PC? USB, Wireless, Ethernet, etc.
    Thirdly, is the printer itself powered up?
    LEXI_48 said:
    HELP SOMEONE PLEASE
    Relax man. Your printer not working probably isn't the end of the world. I can think of far worse things happening than a simple printer issue.
    Now here's what you should do.
    Step 1: If you haven't, reboot your computer. Fix it? Yes-Problem Solved / No-See Step 2
    Step 2: Power cycle your printer (unplug if for 30 seconds or so, plug it back in) Fix it? Yes-Problem Solved / No-See Step 3
    Step 3: Check your printer's connection. Find whatever cable is connecting your printer to your computer and make sure it's plugged it. If it is, unplug and replug it on both your computer and printer. Fix it? Yes-Problem Solved / No-Post back for more help
  2. It is a wireless printer...worked when first got it...now two days later will not work.. thank you for helping...and putting this whole thing in perspective..(many things get blown up out of ...when your alone)....tried what you said still not working. Gave it the evil eye...it laughed at me...lol
  3. For Windows 7 perform these steps:
    Turn printer on:
    Start
    Programs
    Devices and Printers
    Right click the printer icon
    Click see what’s printing
    Click the word printer
    Remove check from use printer offline
    Make sure it is your default printer and restart the computer.
    This might work!
    Do what Area51 said (making sure that nothing is stuck in the print queue). Then possibly try reinstalling the drivers. It's a pretty simple thing to do, and can usually clear things up.
  5. Thank you will try when I come home from surgery today. Thanks
  6. Best answer
    Thank you everyone! I tried the reinstalling the drivers and that cleared it right up! Thank you so much everyone!!!!
  7. This topic has been closed by Area51reopened
  8. Best answer selected by Area51reopened.
Printers Windows 7
