Tom's Hardware > Forum > Mobility Brands > Motorola > HELP!!!! How do you get mp3's to work as ringtones on v400?
Forum Mobility Brands : Motorola - HELP!!!! How do you get mp3's to work as ringtones on v400?
Archived from groups: alt.cellular.motorola (More info?)
HELP!!!! How do you get mp3's to work as ringtones on v400? I can play
them on the phone but can't use them as ringtones, Any help would be
appreciated. Thanks, Steve
Sponsored Links
Two ways to do it: Go to the list of "Sounds" and highlight the one you
want. Press the menu button (top center) and select "Add as Ringtone."
You can also go to Menu: Settings: Audio: Loud Detail and change it
there. It's all in the manual, page 76.
Lose the manual? Download it here:
http://commerce.motorola.com/consu [...] anual.html
me@yomama.com
Reply to Anonymous
Thanks for responding Bruce but the "add as ringtone" option doesn't
come up for the mp3. It's 9 seconds long, 9.74kb, bitrate is 8kbs and
type says AMR. Maybe it's the wrong bitrate or type for ringtones but
it plays it no problem. Would you happen to know the exact specs
required for it to work as in bitrate, length of time, file size
etc... Again thanks for the help, Steve
On Wed, 20 Apr 2005 19:37:43 GMT, "BruceR" <brNOSPAM@hawaii.com>
>From:Metalhead
>me@yomama.com
Reply to Anonymous
Send me the tone and I'll try to d/l it. All my MP3s work the same. Take
the "NOSPAM" out of my address.
me@yomama.com
>> you want. Press the menu button (top center) and select "Add as
>> Ringtone." You can also go to Menu: Settings: Audio: Loud Detail and
>> change it there. It's all in the manual, page 76.
>> From:Metalhead
>> me@yomama.com
>>> play them on the phone but can't use them as ringtones, Any help
>>> would be appreciated. Thanks, Steve
Reply to Anonymous
There are 945 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
