I have been using the RME Multi face with my desktop studio flawlessly
for a while now. I recently needed to get my set up mobile so I
purchased the PCM Card bus interface and have used it with a brand new
DELL Inspiron 9100 notebook. The problem is I get this horrendous
noise; an interference of some kind as soon as the lap top is turned
on. I have been going nuts trying to track down the source of the
noise to no avail. The lap top does have a "wireless" interface card
that I had suspected may be the culprit, but when I tried to disable
it, the noise persisted. Any ideas would be greatly appreciated. the
problem occurs whether I am running on battery or AC.
In article <1102772753.157824.251400@z14g2000cwz.googlegroups.com> MusicMaker1015@aol.com writes:
> on.
I have an Inspiron laptop and found that the power supply puts out a
lot of hash on the ground pin (which affects everything audio that's
plugged into the same outlet). Have you tried unplugging the power
supply from the AC outlet when running it on batteries?
"Horrendous noise" covers a lot of ground. When do you hear the
noise, and what (that you can hear) is connected to what?
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
On 11 Dec 2004 05:45:53 -0800, "Beethovun" <MusicMaker1015@aol.com>
I suspect RFI.
flawlessly
new
the
What is the brand/type of your cardbus controller ?
I have a packard-bell laptop, with a ENE cardbus controller and had
problems with the indigo I/O. There are apparently some troubles with
the ENE controllers (Echo supplied a kind of filter and now the card
works). Might be a similar problem ?
