We're in the middle of building a new 2-floor home and I need a little advice about buying (or upgrading?) our network equipment.
Currently, in our smaller home, I'm using two Linksys WRT54GL's - one as the primary router/firewall and the second as a secondary hub/switch for a few more connections and also as a wireless access point. It's worked fine for many years now but the WRT54GL's are somewhat old, and the wireless is 'g' not 'n'. I've flashed DD-WRT on one of them and playing with it now.
In the new place, the wiring (Cat6) to each room is pulled and terminates in a Network panel on the lower level, in a "mechanical" room where we'll locate the eventual Comcast modem. I'm going to need a router/firewall device (or a combination of router/firewall and switch devices) at this location to handle the 10 leads that terminate in the panel. That's the #1 area that I need some advice... what configuration makes most sense?... and what brands or models are faster and most reliable? Most of our other equipment (PCs, TV, A/V system) is/will-be brand new and close to top-line, so we'll want to take advantage of highest transmission rates.
Additionally, my wireless device will have to be located on the top level of the home, and I'd like it to be as robust as possible which, I assume, means wireless 'n'? That's #2. The guys that pulled the wires suggested Netgear, but I have no personal experience with them.
I'd be more than grateful for any advice or suggestions, either directly or as leads to pages here, or websites elsewhere, which would help me figure this out.
Thank you!
Thank you!
