My Monitor Sound Isn't Working - Help Please
I have this double sided 3.5mm jack. One end went in to the line in circlular slot on the monitor, the other went into the headphone slot on my desktop.
It was working yesterday, thenm it stopped so I redownloaded the driver. It worked again. However, today it isn't working and I've tried reinstalling the driver.
How can I sort the problem out?
This is what appears on device manager:
7 answers Last reply
More about monitor sound working please
  1. Do you often plug and unplug the jack into the desktop? I would suggest that you check the seating of your sound card. Has it come loose for some reason?
    I've only unplugged the jack a few times, I don't understand why it isn't working ........
  3. Heeeeeeelp
  4. You stated you plugged it into the headphone jack on your computer. Is this the jack on the front or top of the tower or is it plugged into the jack on the back of the tower into the Motherboard or Soundcard?
    It's plugged into the front of my case, not the motherboard back panel.
    Have I plugged it in wrongly? I don't know where on the backplate it goes, there's so many same sized holes.
    LOL so I plugged it into the green hole at the back plate of the motherboard and now it's working. However, I'm unsure on why it worked when it was at the front slot of my case in the speaker hole :D
    Oh well, thanks for the idea!
  7. Well the headphone jack on the front should work as well but its possible that its connection to the motherboard is flaky.
    Glad you are back up.
    Flare
Device Manager Desktops Monitors Windows 7
