Tom's Hardware > Forum > Audio > Pro Audio > power supply diode confusion
Forum Audio : Pro Audio - power supply diode confusion
Archived from groups: rec.audio.pro (More info?)
I'm troubleshooting the 6 volt side of a power supply for a BPM tube
mic. I have one failed (shorted) diode left to replace which goes to
ground, in parallel with a filter cap and .002 cermic cap. It comes
between the rectifier output and pin one of the voltage regulator
(7806). I assume the power supply should work without this diode there
at all, and I can't figure out why it's there. The rest looks pretty
much like a textbook power supply cicuit. Can anyone explain what the
purpose of this diode might be and what might be a replacement?
Sponsored Links
Are you sure it goes to ground?
You sometimes see a diode between the output and input of a 78 series
regulator to protect the part from its output going more positive then its
input (which can happen if there is lots of capacitance on the output and
some other load takes the input down quickly).
The 78 series do not like this and tend to suffer....
Just a thought.
Regards, Dan.
Reply to Anonymous
Dan Mills wrote:
tube
to
there
pretty
the
then its
and
> Just a thought.
> Regards, Dan.
There's one there too, but this one definitely goes to ground.
Reply to apa
Dan Mills wrote:
tube
to
there
pretty
the
then its
and
> Just a thought.
> Regards, Dan.
Reply to apa
Dan Mills wrote:
tube
to
there
pretty
the
then its
and
> Just a thought.
> Regards, Dan.
Reply to apa
"apa" <tacoma57@hotmail.com> wrote in message
news:1103413636.365562.76530@c13g2000cwb.googlegroups.com...
Is the filter cap a tantalum? If so this would be an attempt at reverse bias
protection. In any case it is probably for some sort of back bias protection
to avoid destruction of some other component.
bobs
Bob Smith
BS Studios
we organize chaos
http://www.bsstudios.com
Reply to Anonymous
apa wrote:
> Dan Mills wrote:
> tube
> to
> there
> pretty
> the
> then its
> and
> > Just a thought.
> > Regards, Dan.
Output to ground ?
Someone was just being very fussy. I've seen this on some ppl's schematics
before. Usually instead of the diode 'across' the regulator.
Graham
Reply to Anonymous
Could be protection from reverse-polarity spikes caused by something else
sharing the supply. Could just be there because they needed a .6V drop
to reduce the power dissipated by the regulator.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
There are 1313 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
