A slow computer is frustrating. Read this post for emergency tips to troubleshoot your slow computer.
The OS constantly reports running errors? Computer freezes or even gets crashed every now and then? Here in this post you will learn some emergency tips to speed up a slow PC and what is more important, get a plan for such issue.
What Cause a Slow Computer?
Frankly, many aspects can affect the computer running speed and performance. To make it clear and logic, I will simply present you with some common computer errors and the main reasons related in most cases in the list below.
If the computer is clean from any virus infections, common computer issues and corresponding reasons are here to stay:
Retarding responding of the entire OS to your movements ---Lack of disk space (This scenario can result from junk files, excessive unnecessary programs installed, too many tasks processing at the same time, comparatively low configuration of the computer.)
Sudden OS freezing---too many tasks processing at the same time
Occasional OS errors and slow OS running--bloated registry files or registry errors or incompatible programs installed
OS crashed---serious system errors in terms of either software or hardware
Programs unable for normal use--- incompatibility or the program consuming overloading system resources
Black screen or blue screen---software errors or hardware errors
Data Corruption.
Adware & Spyware.
Not enough hard drive space.
Left over programs and bad files.
Missing Windows updates or outdated drivers.
Computer is overheating.
Unnecessary Startup Programs Running in the Background.
Hard Disk Fragmented & in Need of Being Defragmented.
Hard Disk Errors May Be Corrected with "Check Disk".
Hard Disk Needing "Clean Up".
Windows Registry Issues Viruses.
Anti-Virus Security Programs.
Your PC May Need More RAM.
I suggest you a software
speed up pc solve all your problem of slow pc as mentioned above.
I think you like my reply
Regards,
