Laptop not detecting wireless connection
Hello, My toshiba satellite m645 s4112 will not detect a wireless connetion.
7 answers Last reply
More about laptop detecting wireless connection
  1. There is either a button or switch on the front edge of the laptop that will turn on the wireless adaptor.
  2. I pressed Fn+F8 and the wireless adapter indicator lights on.
  3. The light is on and still no connection ? What color is the light , it should be green.
    If nothing then go into network connections and adaptor settings and see if the wireless adaptor is enabled.
  4. I tried that still not working
  5. Try plugging a network cable in and see if you can then detect wireless networks? I'm having that problem on a Toshiba laptop...
    You tried what ? going into the network connections to see if the adapter was enabled ? When you press the Fn button what color is the led ?
    I finally figured it out. My Laptop has buttons that go across the top of my keyboard. They look just like lights and I was thinking that if something was not working they would not light up. I wiped my finger across them and I heard it beep and discovered they are actually buttons. All I had to do was press the wireless symbol and it turned on my hardware radio switch. Problem solved! It only took me a year to figure that out.
Connectivity Wireless Laptops Connection Toshiba Wireless Networking
